Installed RCA blocks on my AWD GS
#91
got a full set for sale if anyone is interested 20mm and 25mm for the fronts and 30mm with camber kits for the rear, take all for $120. had them for a few months rode nicely. also vibrations happen randomly for me depending on the road surface. i have pictures of what they look like on the suspension thread "GS350 AWD Lowering help"
#92
I just got the 20mm RCA adapters installed.
My suspension is fully oem stock.
No vibrations before the install but once i have them installed the vibration is happening only when it is shifted to Reverse or Drive.
When it is on Park or Neutral there are no vibrations.
It is only happening at a stop, when i let go of the brakes the vibration goes away.
Note: this was not an issue prior to the RCA adapters.
Am I the only one experiencing this? any info would help.
Thanks in advance.
Thanks in advance.
#94
So so basically it raises your knuckle by the size you buy so if you buy 25mm then the knuckle goes up 25mm and brings it closer while still having the same suspension travel
#95
#96
#97
Rca blocks
