Suspension Springs, shocks, coilovers, sways, braces, etc.
GS Front LCA bushing bolt number
Old Sep 24, 2025 | 05:07 AM
allarmees's Avatar
allarmees
Default GS Front LCA bushing bolt number
Trying to change the stock bushings for aftermarket ones, I have found every part number except the bolt that threads the bushing to the frame (the one needing to be torqued to around 200ish nm?). Can anyone help?
Old Sep 24, 2025 | 08:17 AM
mspearl95's Avatar
mspearl95
try 91552-L1265.
Old Sep 30, 2025 | 06:14 AM
allarmees's Avatar
allarmees
Originally Posted by mspearl95
try 91552-L1265.
Seems to be the right one. Got it ordered. Thanks!
Old Oct 1, 2025 | 02:05 AM
dwoods801's Avatar
dwoods801
Which lower control arm are you referring to? There is 2, the #1 arm is at a right angle and #2 is kind of am S shape and it attaches to the #1 arm and rhe bottom of the car. The one that bolts to the bottom the car can be tricky to prefer a new one and tricky to remove and replace. They increased the bushing size in 2001, and went from 60mm to 65mm. You can actually just replace the whole arm with the mewer, bigger one. If you’re looking to get the best handling possible then you want to replace all the rubber bushings with polyurethane. But if your just wanting to restore the ride and handling to how is felt new then i would suggest just buying replacement arms with the rubber bushings pre installed. It’ll make the job much easier and more affordable, and will still improve the car substantially.
Old Oct 1, 2025 | 02:16 AM
allarmees's Avatar
allarmees
Changing 48075;48076 part number
Old Oct 1, 2025 | 02:23 AM
dwoods801's Avatar
dwoods801
Is it the 60mm bushing or the 65mm bushing? Which one does your car have?
Old Oct 1, 2025 | 08:16 AM
allarmees's Avatar
allarmees
As you said 2001 and onwards uses 65mm so I believe it's that.
smitty2919
Suspension and Brakes
12
Aug 19, 2025 09:13 AM
goose300
Jun 3, 2024 02:38 PM
sean110930
May 7, 2023 12:42 PM
KC95SC400
Apr 14, 2022 07:41 AM
BayAreaLex
Sep 25, 2012 04:08 PM
