Suspension Springs, shocks, coilovers, sways, braces, etc.
Should I replace both control arm and ball joint?
Old Mar 18, 2025 | 09:51 AM
Dflores's Avatar
Dflores
5th Gear
Default Should I replace both control arm and ball joint?
I recently bought two new ball joints (front lower ball joints from premium MEVOTECH on rocksauto) and going to take it the shop (300 for labor/alignment) I was suggested by a relative to replace both even though one is bad I did it because the ball joint wasn't too expensive, I did some research and some say you should also replace the control arm. Should I? Anyone had a similar situation? Should I just replace the damaged one?
Wilson2000
Aug 31, 2024 09:24 PM
jhomer42
Feb 19, 2024 07:34 PM
DanIrl
Jul 21, 2018 10:49 AM
frankjames
Suspension and Brakes
Jul 20, 2009 09:51 AM
92blacktt
May 17, 2009 05:32 PM
