is alignment needed?
Old Aug 19, 2003 | 05:25 PM
bluelex's Avatar
bluelex
Default is alignment needed?
if i raise my car up a couple of threads on the coilover in the front will i need 2 redo my alignment? i'm starting 2 c tires ware already and want 2 raise it so the tires make it till the camber comes out , which should hopefully b in the next couple of months.. i'm hearing a woo woo sound from them ..i hope i don't need new tires now.
Old Aug 19, 2003 | 06:11 PM
LS4fun's Avatar
LS4fun
Well..tires won't wear as much if you dont drive that big pimpin ride 400 miles a day! ..J/k...alignment should really be done whenever you adjust drop height of car..
Old Aug 19, 2003 | 06:18 PM
RON430's Avatar
RON430
In fact, why not kill two birds with one stone and take the car in for an alignment and play with the ride height while it is on the aligment machine? Probably wouldn't be able to do it at Costco but a good suspension shop shouldn't have any problem with working with you a bit to get a better balance of alignment for tire wear vs drop. Just a thought.
Old Aug 19, 2003 | 06:35 PM
D2-AUTOSPORT's Avatar
D2-AUTOSPORT
Former Sponsor
A,
In order to slow down the effects of negative camber wear, "flip" your tires. Take the rims off the car, take the tires off the rims, then flip the tire around to the other direction, then install the tires on the opposite side of the car.
A good way to extend tire life, especially with you having a staggered set up.
bluelex's Avatar
bluelex
thanx. i need 2 lift this thing a little cus it starting 2 make a lot louder road noise. my shop guys is real cool, he should b a ble 2 do what u mentioned. when i got the coilovers put in i had a finger gap in the front now they r tucked, i gues they fnally settled. but if i left her again 2 a finger gao will it settle again and throw the alignment off again...
Old Aug 19, 2003 | 07:00 PM
D2-AUTOSPORT
Former Sponsor
A,
Maybe that whoo whoo sound is because your wheels need a balance (bumps and stuff can throw it off). Also they may be slightly warped on the inside from bumps. Do you hear that sound at 15-20 mph?
Old Aug 19, 2003 | 07:29 PM
bluelex's Avatar
bluelex
i hear it at 15 to 20 thans its at its loudest at 45 to 60
Old Aug 19, 2003 | 09:00 PM
rominl's Avatar
rominl
exclusive matchup
well as long as you like the current height, go do an alignment. that's what i do. keep on adjusting the coils until i like it and then i will do an alignment
Old Aug 20, 2003 | 03:12 AM
UncleNick's Avatar
UncleNick
Hey buddy, bring that beast over and lets get it done before your tires go to crap. I can do it anytime for you .
Did you get the camber kit ? If I remember right your camber adjustment is now maxed out, correct? It would not hurt to invest in the kit for the front. Let me know either way. Call me at the shop today!
Old Aug 20, 2003 | 04:58 AM
lexforlife's Avatar
lexforlife
hey blue
welcome to the world of pole position so3 my friend and i run the exact same set up and i have found depending on outside ambient temp and humid the tires will make the noise louder if the temps and humid are up ,,, when surface temps drop lets say around 80 and below they tend to quiet down.. but the poles tend to get louder as they wear in ..and the neg camber does not help it either.. i did the flip thing up at Good roads place on commerial blvd (by the way they have the hunter mach and those guys know haow to exract a perfect bal every time,, if you go ask for pete , hes the bald headed kid , he really takes his time just tell him you will take care of him after)
Old Aug 20, 2003 | 06:26 AM
sung35's Avatar
sung35
Hey guy, where can I find a camber kit online? Thanks.
Hung
Old Aug 20, 2003 | 06:34 AM
bluelex's Avatar
bluelex
nowhere. the camber kit isn't out yet 4 the GS.. might b out by oct or nov so i'm lifting her back up until it comes out and than drop her again later...
Old Aug 20, 2003 | 08:06 PM
bluelex's Avatar
bluelex
well car is going 2 the shop 2marrow moring so i'll let u guys know what happen,,,
Old Aug 21, 2003 | 08:59 AM
bluelex's Avatar
bluelex
ok guys everything went well this moring the loud sound is much lower and it not swirving 2 the right so far. i just want 2 than nick and his guys at his shop 4 there help...i raised the car a little and have even camber now so its good 4 now....
DPK*David
Nov 19, 2015 01:28 PM
Toastt
Sep 14, 2010 07:10 PM
MarcusMIA
Oct 14, 2009 07:08 PM
mcyc
May 12, 2008 01:13 PM
