GSF/RCF Bushing Offset
Old Apr 26, 2019 | 11:37 AM
  #31
ex00's Avatar
ex00
Car is a little over 7,000 miles so hoping that there isn't issues when it comes to installing. Probably just take it to a shop to make things easier before I mess up completely. Thanks guys! Really informative on the information!
Old Apr 26, 2019 | 11:54 AM
  #32
Flash5's Avatar
Flash5
Originally Posted by Sasnuke
Lol...no judgement taken Flash...all good.
I was just pointing out that the hand tools is likely a better choice in this scenario...and of course not everyone has a compressor and impact gun available to them...but still need to get the job done.
As for my bushings, i just pulled the back of the arm down slightly and they slid off...I was surprised. I had a pry bar and hammer at the ready...didn't even pick them up.
Seems we had quite the different install experience lol. Maybe the fact that I have a 2018 and you have a 2014 also made a difference?
Old Apr 26, 2019 | 04:19 PM
  #33
TOPENDMS's Avatar
TOPENDMS
Former Sponsor
I have a Milwaukee Cordless Impact Gun. Didn't even use it for Air Lift Suspension installation. It's really only good as a breaker bar replacement in tight situations. I hate how it knocks on the bolt .. very easy to damage nuts/bolts. Completely over rated.
Old Apr 28, 2019 | 05:25 PM
  #34
ex00's Avatar
ex00
Thinking about getting one eventually down the line for bolts that are really stuck on, ran into several on various cars in tight angles where it's difficult to even use a breaker bar.
Old May 27, 2019 | 06:25 PM
  #35
Jbreezie's Avatar
Jbreezie
Just did it. Only took me 4 hrs haha wish I had a lift. There was a learning curve for me, had to redo a side a few times.
Old Aug 25, 2019 | 11:31 AM
  #36
Miintt's Avatar
Miintt
@Sasnuke would I be okay with the 0 offset bushings or should I get the other offset ones? My alignment sheet is attached
Old Aug 25, 2019 | 12:42 PM
  #37
Sasnuke's Avatar
Sasnuke
Based on the sheet, Toyota recommends no more than 0.5 difference (side to side) in Caster. You're at 0.4, so not quite an issue.
I would say this...if the vehicle is driving straight for you, then get the 0 offset bushings for both sides.
If you have any kind of drifting or wandering to the right, then get the 0 offset for the driver's side and the + offset for the passenger side...that should bring the Caster within 0.2 difference and clean up any drifting or wandering to the right.
Old Aug 28, 2019 | 06:50 PM
  #38
Miintt's Avatar
Miintt
Thanks! I went ahead and got the 0 offset ones.
Old Sep 16, 2019 | 07:40 PM
  #39
axes2k's Avatar
axes2k
i have a 2019 is300t, anyone if they are still the same as older models? any shop recommendation around socal for LCA replacement?
Old Sep 17, 2019 | 04:47 AM
  #40
Sasnuke's Avatar
Sasnuke
There's no indications that the control arm bushings have changed...or will change.
Old Sep 20, 2019 | 09:05 AM
  #41
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
Regarding the difference in torque value for the AWD/RWD, that bolt attaches the subframe (which is very different) and while the bolt is similar, it actually is a different part for AWD (90119-16022) and RWD (90119-16021).
As far as the bushings go, they're the same fitment for 2006-2020.
Jeff
Napalvr
Suspension and Brakes
30
Feb 13, 2021 01:14 PM
diljay
14
Nov 4, 2020 12:42 PM
Lrguy1989
Jul 11, 2016 03:21 PM
adamls2
Mar 24, 2011 12:12 PM
