Bilstein HD B6 with Vogtland Progressive Springs
This weekend I finally was able to upgrade the suspension in my 2003 GS300 with 115k miles.
It still had its OEM Lexus Shocks.
I have had the rear Bilstein shocks since September, but the front had been on back-order for months and finally arrived in early November.
The Vogtland Progressive Springs are from 6 up to 9kg/mm in the Front, and from 4 up to 5kg/mm in the Rear.
Ready to Install
Front
Rear
So, far in the few miles I have driven it is a vast improvement.
The OEM Front Shocks were literally SHOT. The piston shaft move in an out with no resistance.
The OEM Rear Shocks were a little better, but had very little damping ability left in them.
Ready to Install
Front
Rear
Nice upgrade. I did this upgrade 4 weeks ago but with the Bilstein B8 Sport shocks in lieu of the B6 HD. I'm very happy with the Vogtland and Bilstein combo. The car feels fantastic.
Brake and Rotors
I also rebuilt the calipers myself.
I will NEVER pay for a rebuild caliper again.
It really is very easy assuming you have compressed air, otherwise it would be impossible to get the caliper pistons to pop out.
I then thoroughly cleaned, primed and painted the calipers with high temp engine paint.
Then finished them off with high temp clear coat.
I like the color, it is classy without screaming "look at me".
Here are some before and after photos.
The B8 bodies are an inch shorter than the B6's.
I called Vogtland and their engineer said the Vogtland Lexus GS300 Sport Lowering Spring should work with either shock body length, so I went with the OEM length B6's.
Thanks for sharing. Would you mind posting pictures of ride height, and equally as important - what's the sense of the ride? I have the same shocks (ordered over a year go - got them last week) and am trying to figure out what, if any springs to change to. I like the L-Tuned look but they've been out of production for some time. Eibach as well. At this time I was considering the Tein Htech for it's minimal (1" drop and smooth ride). This spring you have installed I'm not familiar with. I wouldn't mind a touch more spring rate than stock, but don't want to be even close to a harsh ride and would like to close the gap a little (1"-1.5").
Here are some quick pictures I just took.
Ride height is about 0.75" lower than OEM, and I suspect it will drop another 0.25" over time as it settles in.
Ride is very smooth and competent with great turn in.
I have hit the bump stops going over speed bumps, but that is to be expected.
Maybe Landarch20 can give more info since he has had this basic setup for about a month.
NOTE: AJUSA does not have these springs on their website, but they sold them to me for $210 Shipped.
Thanks for the input. I'm curious as to what the factory spring rates (I understand variable) are. Do you feel like these spring rates are slightly firmer than factory? I'm looking for a slightly firmer ride but not anything harsh.
You mention bottoming out on a speed bump. I frankly wouldn't expect that, given a relatively normal speed bump and an unloaded (or kid-load) rear seat area. Can you give me some details about this? I've bottomed out my front stock suspension on a downhill braking area that has a very subtle dip where in the wife's newer car it never occurs. I've always expected this occurs in the Lexus due in no small part to the fact that the factory struts have 227k miles on them. But post Bilstein install, I expect / hope this to be a thing of the past, even with stock coils
Looks like some nice NA Miatas in the background with some suspension work done as well.
You shouldn't be bottoming out if you're driving over things at a reasonable speed. I have B8s and H&R sport springs and I've only bottomed out over a really big dip I took way to fast (at about 50 and I should have been going 25). I can go over speed bumps at 40 and its still comfortable and doesn't bottom out but the ride is definitely firmer than stock. Similar to a new BMW 340 or 440 with the M package
I have sent you a PM with my contact info if you have any questions.
KyleH (11-23-18)
Thanks so much for all the valuable info, Flash. Parts are all on order, including the Springs. Your thorough cataloging of parts and fresh experience in this space was super helpful. I had a chance to get after the lower suspension parts (ball joins, control arms) when I first picked up the car a few years back, so they're fairly fresh still. When I get a chance to compile, assemble, and install I'll post an update on my build thread. Then on to brakes and wheels / tires and this old gal will be looking and feeling a lot more fresh than she sits today.
Bilstein & Vogtland Suspension Parts List
If anyone is interested here are the parts and suppliers that I used for this setup, plus some other parts that I replaced around the same time as the rest of the suspension.
My total cost was about $1,150, and that included the front upper control arms, front lower rear control arms, the front lower ball joints, and outer tie rods.
Scorchez (02-16-24)
Great post, Flash9. I also got some B6s that I will be combining with some Eibach springs. I chose the B6 given how modest the lowering is, and so I can go back to stock springs if I desire.
One thing I noticed - you kept the spring perch in the upper position. Any reason in particular? Bilstein ships it this way, but my understanding is that this will lift the car if used with stock springs. I intend to put mine in the lower positions.
3 Years ago: (Stock)
After installation of Vogtland & B6 (upper perch all around)
After lowering rear springs to lower B6 perch
After a couple weeks of mostly sitting - maybe 35 miles driven - the rear is sitting 1/2" higher than the front in terms of bottom edge of fender relative to the wheel. As I recall, the difference between the upper and lower perches was somewhere between .5" and .75"
Given you have different springs, your results may vary. But I too have read of people going on lower perch front and rear. I don't think I'd want to go any lower on the front given I like the look of where it is and I wouldn't want additional offset in height front-to-rear. So I'm happy with top perch of front, lower perch in rear for these particular springs.
I will say I need to adjust the headlamps, as they're not throwing light out far enough in front of me any longer. This has more to do with the fact the front is so much lower than before relative to the rear.
