Wrong tein part or mine is different
Old Aug 9, 2017 | 11:35 PM
hijack87's Avatar
hijack87
Default Wrong tein part or mine is different
so i ordered the monosport touring of tein for my 2017 is350 rwd. And **** it doesnt fit. The the 2017 change suspension arm or is this only in the PH. Crap!!
Old Aug 10, 2017 | 05:42 AM
Sasnuke's Avatar
Sasnuke
The front lower control arm on a 2017 RWD is different to a 2014-2016 RWD.
Another member discovered this also.
It appears the control arm changed from steel (2014-2016) to aluminum (2017+).
Also, the bushing that was in the bottom of the strut (2014-2016) has now been moved into the control arm (2017+).
The 2017+ RWD front lower control arm resembles more closely the 2014-2016 AWD front lower control arm. I don't believe they are the same though...haven't seen any part numbers to confirm.
Old Aug 10, 2017 | 08:19 AM
fivesevenn's Avatar
fivesevenn
Tein website says it hasent tested for is350 oct 2016 onwards.
i can check if your is350rwd is same as 2014-2016 (part numbers) but will need your vin.
Old Aug 10, 2017 | 05:17 PM
hijack87's Avatar
hijack87
I figured this was the case when I started looking at lexus oem parts. So now I think my option is to change the lower control arm back to the 2014-2015 models
Old Aug 10, 2017 | 05:30 PM
hijack87's Avatar
hijack87
When I enter my VIN in lexusparts.com it shows 2016 model (JTHBE5D24G5028706)
I actually started looking and I think the previous control arms would fit since the other components like the knuckle, control arm bracket and suspension crossmember have the same OEM numbers (except for the suspension). This is the reference I used click here from oemlexusparts.com
So I got these numbers for the LH and RH
  • 4864053020
  • 4862053020
Current numbers are; supposedly according to oemlexusparts.com:
  • 4864053050
  • 4862053050
Hope you guys can confirm if this will be no problem or will I have to kill my self
Old Aug 11, 2017 | 05:46 AM
fivesevenn's Avatar
fivesevenn
Dont compare with a 2014, some of the parts were carried over from previous gen.
from what i see, the rears are the same, the fronts are different from rwd/awd f-sport models. 2016/2017
this is just searching for front shocks
Old Aug 11, 2017 | 05:58 AM
Sasnuke's Avatar
Sasnuke
I think hijack may be considering swapping the front lower control arms on his 2017 RWD for a 2014-2016 RWD.
That would resolve his coilover fitment issue.
Although, considering the difference between the two control arms, I would stick with the 2017 ones...but then the coilovers won't work.
Old Aug 11, 2017 | 05:30 PM
fivesevenn's Avatar
fivesevenn
i agree as well to stick with the control arms, im waiting longer for new products for the 2017 (coilover/springs/shocks)
Old Aug 12, 2017 | 09:24 AM
hijack87's Avatar
hijack87
I couldnt wait so check out the pics of the install. The parts I needed to to get was the control arm and stabilizer links and thankfully its installed . check out the pics
Shorter one was from the 2017.
Correct me if I'm wrong so this means I'm the only one that has coilovers installed on a 2017? lol.
Old Aug 12, 2017 | 12:56 PM
Sasnuke's Avatar
Sasnuke
Damn...hijack was serious about getting them coilovers on. Respect to the mechanic for doing that on the ground.
I think you definitely get first place for the first 2017 RWD lowered on coilovers.
Unfortunately corradoMR2 snags first place for 2017 overall, his 2017 AWD is lowered on Neosport coilovers from a few months back. I don't think there was a change to the AWD front lower control arm...it's already aluminum with the bushing in the arm for the strut support bracket.
Old Aug 12, 2017 | 02:04 PM
fivesevenn's Avatar
fivesevenn
looks very nice!
Old Aug 14, 2017 | 05:13 PM
specONE's Avatar
specONE
Sasnuke tells the truth
To add to his explaination, the 2017+ front suspension is more like the GS and RC front suspension now so coiloveres for 4GS and 1RC will work for +17' IS
Old Aug 14, 2017 | 06:50 PM
3actual's Avatar
3actual
Hijack - please post pics of the finished product, and let us know how the coilovers ride. I have been considering those coilovers.
Old Dec 27, 2017 | 12:39 AM
Defender15's Avatar
Defender15
Hey hijack, what site did you buy the parts from? Can you give me the part numbers of everything you needed? Im moving foward and going to change the arms to 2014-16. Did you have to change anything in the back or didnt seem to be an issue.
thanks. I got k sport coil overs brand new in the box with my new niche misanos just waiting for me to install.
Old Aug 9, 2021 | 02:20 PM
MotoPasion's Avatar
MotoPasion
Sorry for reheating old topic..
But can someone tell me what exact control arms i need to install front coilovers (i have aluminium control arms and wrong front coilovers)
Steel control arms from Lexus IS II will fit the IS III ? (i ask cause i don't from which car are these control arms on the photos)
