Reasonable install price in CA?
Old Jul 22, 2017 | 03:45 PM
Yodog's Avatar
Yodog
Default Reasonable install price in CA?
What's a reasonable price for an install for the following parts? If anyone knows somewhere legit who can install these correctly please do tell or PM me. I'm trying to get these installed THIS week but the last shop i went to said they couldn't do it themselves but still quoted me $1200 essentially them just being the middle man. Anyways here are the parts:
-DIAZEN Steering Rack Bushings
-Ultra Racing Rear lower 2-point power brace bar (per side)
-Philips H11 X-tremeVision headlight *low beam* replacement (pair)
-Philips 9005 X-tremeVision headlight *high beam* replacement (pair)
-FIGS IS-F ‘Track Spec' FUCA (Front Upper Control Arms)
-FIGS Front lower rear arm mount #1 Polyurethane 90Duro bushings (2-bushings per side to replace both bushings in both arms)
-FIGS Front sway bar end-links (pair, one per side)
-FIGS Front sway bar SuperPro polyurethane bushings — 30mm
-FIGS Rear sway bar end-links, (pair, one per side)
-FIGS Rear sway bar SuperPro polyurethane bushings — 19mm
-FIGS MEGA Rear upper link arms #1 and #2(two links per side, four total)
-FIGS Rear upper trailing link knuckle mount polyurethane bushings (2 bushings, one per side)
-FIGS Rear lower 'TRAC Link” traction control arms (one per side, two total)
-FIGS Rear Knuckle “Trac Link” Press-In Spherical Bearing Bushings Replacement
-FIGS Toe Links (one per side)
-FIGS MEGA Arms GEN2 IS / IS-F “Race Version” V2 Complete LCA (Lower Control Arm) Replacement
-FIGS Rear Knuckle Lower Rear Press-In Spherical Bearing (LCA)
-FIGS Rear Differential Pinion Mount Modular Performance Polyurethane Bushings - Inverted Mounting
-FIGS Rear Differential Mount Polyurethane Bushings - molded face-mount (like factory mount) 90 Durometer
Any help or information on what a reasonable price would be to get these installed would be much appreciated. All I know is the place needs to have a heavy shop press/C-Clamp service tool.
Old Jul 22, 2017 | 04:30 PM
MikeFig82's Avatar
MikeFig82
Finally someone made the Steering rack bushings. How long they've been out?
I had these on my old GS400. It removed the slop from the steering wheel. I'm ordering them right now. LOL
Old Jul 26, 2017 | 07:32 AM
MikeFig82's Avatar
MikeFig82
Did you order your steering rack bushings from TM Engineering? If so have they been shipped? I ordered mine Saturday, and it still says processing.
Thanks
Old Jul 26, 2017 | 07:37 AM
Yodog's Avatar
Yodog
Thanks
funny you mention this. Yes I ordered from TM Engineering and I received it yesterday in the mail via USPS. Just follow that usps tracking number link, then once you 'track shipment' it, just set it up so you get text messages or email updates for delivery attempts. Doesn't say this but this option also includes letting you know when the item is delivered so you know when to go and check your mailbox. I hope this helps.
Old Jul 26, 2017 | 08:48 AM
MikeFig82's Avatar
MikeFig82
Yes but my order still has no tracking info associated with it. I opted for UPS ground. Hopefully it will just show up.
Weapon F
IS F (2008-2014)
12
May 8, 2020 10:55 AM
BayAreaLex
Suspension and Brakes
12
Nov 20, 2012 10:46 AM
redliner8
Aug 8, 2011 07:03 AM
Red Bully
Sep 6, 2008 04:42 PM
