IS350 Brake Conversion
Old Apr 25, 2018 | 06:12 PM
Flashisf's Avatar
Flashisf
Originally Posted by Losdavos
No spacers needed for OEM wheels. You should not need spacers for most aftermarket wheels so long as they will fit an Is350.
Dave
thank your reply
Old May 15, 2018 | 11:49 PM
Jbreezie's Avatar
Jbreezie
Are the caliper mounting brackets the same? I’m debatinf if I should purchase from Partsgeek.com or RockAuto.com
Old May 16, 2018 | 05:09 AM
Sasnuke's Avatar
Sasnuke
The 250 front calipers are floating calipers, so they require a bracket. The 350 calipers are fixed calipers, so basically the bracket is built into them.
You can see some pics of the transformation of the 250 to 350 calipers (on an AWD): https://www.clublexus.com/forums/bui...l#post10158779
Old May 17, 2018 | 10:58 PM
Jbreezie's Avatar
Jbreezie
Thanks, Weird how some say mounting bracket not included. Did you change the dust shield or modified it?
Old May 18, 2018 | 05:36 AM
Sasnuke's Avatar
Sasnuke
I guess you can say the mounting bracket isn't included...cause there isn't one for the 350 lol
The rear calipers on the all the 3IS's are floating calipers, so they all have brackets.
The 350 front caliper bolts directly to the steering knuckle...you can use the same bolts from the 250 that hold the bracket to the steering knuckle.
The dust shields i replaced. They were $15 each I believe, and are different if you have AWD opposed to RWD.
For AWD to replace the dust shields it's definitely more work, but it's looks so much cleaner after, and it's done right.
Not to knock or judge anyone that "modified" the shield, I just prefer it to be proper.
If you have a RWD it's much easier.
I would recommend getting two bolts that are longer than the ones that hold the wheel bearing assembly onto the knuckle, and an air hammer.
Using the two bolts installed diagonally, you carefully air hammer each one alternately, and the wheel bearing assembly will pop right out...if it was rusted in like mine...but that's due to environment mostly.
In those warmer climates, you could probably use the original bolts, just loosened 4 or 5 threads, and some love taps with a regular hammer.
Old Jun 11, 2019 | 06:48 PM
Ajowhan's Avatar
Ajowhan
Hi, I am looking to do the is 350 brake conversion for my 250. In most of the post I have found, everyone seems to "modified" the dust shield. I like to do things proper myself and was wondering the parts number for the dust shield that you replaced it with?
Thank you Sasnuke
Old Jun 11, 2019 | 09:26 PM
Sasnuke's Avatar
Sasnuke
Thank you Sasnuke
Here's my complete parts list...keeping in mind my 250 is AWD:
If your 250 is a RWD, then the rotors and backing plates are different part numbers.
Old Mar 26, 2020 | 07:05 PM
Danny1583's Avatar
Danny1583
hey guys, so I'm doing my 250 to 350 conversion tomorrow, but I was curious what did you guys do about the rear setup? did you change the calipers and rotors too? because aren't they different in size, or did you guys just paint the calipers to match your new front brakes? thanks. Im guessing ill just paint my rear calipers to match my fronts
Old Mar 27, 2020 | 05:35 AM
Sasnuke's Avatar
Sasnuke
For the rears I didn't do anything...just left the 250 rear brakes.
Yes...the 350 rear brakes are bigger, but you likely won't notice the difference unless you park the two versions of the car back to back.
Also, with the rear only doing about 35% of the braking, it's not worth the hassle of swapping it as well.
GS400Star
Aug 1, 2011 01:37 PM
amiehe
Suspension and Brakes
Apr 26, 2011 08:24 PM
BJM711
Oct 31, 2009 07:38 AM
unit74
Oct 18, 2007 10:16 AM
THoon
Aug 3, 2007 05:02 PM
