Complete Suspension Refresh/Overhaul
I also see 3 different options from Figs which I assume would be for those of us who are super low? I am currently on KYB shocks and DF210 springs, but will most likely be going coils later on down the road, so what option should I go with IF I decide to go with Figs?
http://shopfigs.com/v3/G2GS300ADJCST2-40-SPF
http://shopfigs.com/v3/G2GS300CST2-40-SPF-N
http://shopfigs.com/v3/2GS_SC430LCA-CK40_41_86
He said that you can tell by spinning the wheel hub (?) and if you hear a whining noise, then it's about to go out. You can also tell if you smell burning grease, which I did smell for the past week after driving to work in the mornings.
These bushings are just as much as the arm and the stock bushings. Or am I missing something? Sorry I am a noob as well.
Btw if you are gonna go the OEM replacement route, upgrade to the beefier arms. They have the small little bump near the bushing end. If you are purchasing the Figs bushings, the older 98-00 arms (some 00 will have the beefier arms) have no bump at the end, but the 00+ will have the bump. The bushings will be a different size as well, so you will want to get down there to take a look before purchasing.
For example:
Front Tension Rod
http://www.hardrace.com/Product_detail.asp?id=3667
and well you can check out all there stuff they have at:
For example:
Front Tension Rod
2003 LEXUS GS300 3.0L L6
Suspension : Ball JointRelated PartsBall Joint BootBall Joint PressJoint Separator / Pickle ForkSteering & Suspension Repair ManualSuspension KitTie Rod EndMOOG K500102 {#4334039415, 4334939415} Problem Solver InfoFront Left Lower; Design Allows Ease Of Installation
$33.79$33.79MOOG K500101 {#4333039535} Problem Solver InfoFront Right Lower; Premium Sealed Boot Keeps Contaminants Out
$33.79$33.79
Suspension : Control ArmRelated PartsSteering & Suspension Repair ManualSuspension KitMOOG RK640409 {#4806830300} R-Series InfoFront Right Lower; Arm Only
$67.79$67.79MOOG RK640410 {#4806930300} R-Series InfoFront Left Lower; Arm Only
$67.79$67.79
No Vehicle Specified
Steering : Tie Rod EndRelated PartsBumperJoint Separator / Pickle ForkStabilizer Bar BushingSteering & Suspension Repair ManualTie Rod End BootMOOG ES80585 {#4547059015} Problem Solver Info
$19.11$19.11MOOG ES80584 {#4546059015} Problem Solver Info
$19.22$19.22MOOG EV80600 {#4550339155} Info
$29.79$59.58
Suspension : Control ArmRelated PartsSteering & Suspension Repair ManualMOOG RK620335 {#4861039085} R-Series; Complete Arm w/ Ball Joint Info
$111.79$111.79MOOG RK620336 {#4863039055} R-Series; Complete Arm w/ Ball Joint Info
$111.79$111.79
But in total you need (for the front), in total: left and right upper control arm with the ball joint pre-installed, left and right lower ball joint, left and right lower control arm #1, left and right lower control arm #2 aka caster arm, left and right outer tie rod end, left and right stabilizer bar end link, stabilizer bar bushings (2 per vehicle), and steering rack bushing (1 kit per vehicle).
