Alignment Specs. Please comment.
Old Dec 3, 2015 | 06:36 PM
DUMSI's Avatar
DUMSI
Default Alignment Specs. Please comment.
2011 Lexus IS 250 RWD, Got all 4 tires replaced and alignment done at the dealership. Now the the car drifts to the right. There is .1 degree difference in caster from side to side (7.2 left, 7.3 right). Is this difference enough to cause a drift to right even if the caster is lower on the left? Below is a picture of the before and after alignment specs. Does the specs look right?
Thanks in advance.
Old Dec 3, 2015 | 10:56 PM
MWIS350's Avatar
MWIS350
What does the alignment shop say? Sorry I don't know ho two read those.
Old Dec 6, 2015 | 09:23 PM
Gville350's Avatar
Gville350
Same thing happened to me. My drifting issue ending up being fixed with an adjustment to the front cross member I believe. I'd not worry about those very minor caster specs in the red. As you can see, they're VERY close to spec. The best thing is to ensure their even, or as close as possible to even.
Old Dec 6, 2015 | 11:53 PM
MWIS350's Avatar
MWIS350
You might need to install ball joint to correct alignments.
Old Dec 7, 2015 | 12:04 PM
WylieKylie's Avatar
WylieKylie
^ What "alignments" are you going to correct with "ball joint"?
Old Dec 7, 2015 | 10:06 PM
MWIS350's Avatar
MWIS350
My mechanics recommended for the front.
Old Dec 8, 2015 | 01:05 PM
WylieKylie's Avatar
WylieKylie
My point is if you don't know what you are going to adjust, there is no sense in throwing new parts into the mix.
Adjustable ball joints on the front will add the ability to adjust the camber. Camber in the above sheet is absolutely fine so adding the ability to adjust it won't help.
Old Dec 8, 2015 | 07:15 PM
MWIS350's Avatar
MWIS350
My mechanics will install ball joint to correct negative chamber. He also have machine for alignment in front.
Chazzer96
Feb 26, 2019 07:22 PM
Danny200t
NX - 1st Gen (2015-2021)
Nov 9, 2018 05:33 PM
PhantomV
Oct 13, 2014 11:43 AM
irokdastar
Jun 10, 2011 03:04 PM
eppan
Dec 20, 2001 05:41 PM
