Help Broke ball joint
Old 03-16-14, 05:10 PM
KleeNx11
KleeNx11's Avatar
Default Help Broke ball joint
I broke the ball joint where the upper control arm meets (passenger front) Im dumped on coils with stock wheels. I need some advice on how to replace just the ball joint. any DIY?
Old 03-16-14, 05:45 PM
Gville350
Gville350's Avatar
When that happened to me, I actually installed SPC adjustable ball joints, since like you I'm slammed on coils with stock wheels. It'll help you during the alignment. They do have OE replacement ball joints though too, which will have to be pressed in.
Old 03-17-14, 12:25 PM
KleeNx11
KleeNx11's Avatar
Where could i buy a oem ball joint? I read somewhere that i have to replace the whole upper control arm? is that true
Old 03-18-14, 12:48 PM
Gville350
Gville350's Avatar
^Used to be true, but now there are companies making JUST the ball joint itself. Google my friend.
Old 03-19-14, 10:26 AM
maddnotes
maddnotes's Avatar
I bought one from Napa, I think it was right around $50. Was even able to press it in without removing the upper control arm.
Edit: I found the part number ATM SBT291
http://www.napaonline.com/Catalog/Ca...291_0307082492
Old 03-19-14, 03:11 PM
KleeNx11
KleeNx11's Avatar
I recently purchased a ball joint from MOOG. Is AWD and RWD ball joints the same?
Old 03-20-14, 09:28 AM
maddnotes
maddnotes's Avatar
I believe they are because the part numbers listed for the upper control arms for both RWD and AWD are the same.
Old 03-20-14, 05:42 PM
KleeNx11
KleeNx11's Avatar
@maddnotes Thanks for the help. I really appreciate it!
JAB
RX - 1st Gen (1999-2003)
11-30-18 03:38 PM
Returd
Suspension and Brakes
12
09-12-17 06:04 PM
O1GS43O
06-01-10 08:34 PM
frankjames
07-20-09 09:51 AM
Benjamin T
12-29-07 07:20 PM
Quick Reply: Help Broke ball joint
