Need help and suggestions on rebuilding front end
Old 01-20-14, 06:52 PM
KickItOut
KickItOut's Avatar
Default Need help and suggestions on rebuilding front end
I'm getting ready to put a lot of money into the sc300, yay tax refund. I want to start with rebuilding the front end, tie rods, bushings, steering rack, adjustable control arms. Can you guys help me with what all you think I need and where should I get the parts from? All suggestions welcome. My final goal is to rebuild front end, get rid of crappy suspension set up and get coilovers, and finally, drop in a 1jzgte with an R154, but first things first I gotta get this front end up to par. Thanks guys
Old 01-21-14, 10:17 AM
SCereal
SCereal's Avatar
In for details myself. Seems like so much is available now for our cars that didnt exist even 3 years ago.
Old 01-22-14, 06:09 AM
Maserati
Maserati's Avatar
For the most part sway bars(maybe) sway bar end links, lower control arm bushings, upper control arm bushings, steering rack bushings, tie rod ends & boots, new struts/shocks. brakes, calipers, rotors, so much more. i did my major bushings so now i m looking at getting new suspension components ie.coilovers. but you dont have to change much unless it looks bad or you feel a problem. Make sure you check the boots on the control arm and the tie rod ends.
Old 01-22-14, 07:32 AM
KickItOut
KickItOut's Avatar
The whole front end feels loose and I can't seem to maintain an alignment, also I want to take some camber out
sidwin
Suspension and Brakes
23
11-11-12 02:53 AM
ceelo
07-07-11 04:26 PM
djkevin510
12-07-08 04:59 PM
kingrich
05-25-08 01:11 PM
SC3005SPD1
14
12-08-07 02:17 PM
Quick Reply: Need help and suggestions on rebuilding front end
