Megan Front Upper Camber kit question..
#35
Popping my head in here to see what current 2IS aftermarket front UCA owners have experienced over time. I ask because, in general...not just 2IS owners, comments include over time that the hardware to keep the ball joint in place relaxes and then proceeds to move/slide around. Seeing what 2IS owners have experienced and what advice to give, as I've invested in a set to finally get my front-end into factory camber specs. Already went through my set and chased the threads on one threaded hole that was slightly messed up; but other than that, a decent set with better welds than expected. Torqued the bolts down to spec once and released. Definitely tight enough to not move when torqued after hitting the ball joint with a dead-blow mallet.
Thanks all!
Thanks all!
#36
Thanks all!
Thanks all!
#38
on an ISF for about a year also with zero issues loosening over time, including 4 track days. I check them anytime I have the front wheels off, usually 6 times
a year, they've never loosened. I also regularly check camber with portable gauge and camber has remained constant.
Sportskid1
Suspension and Brakes
35
12-13-13 10:59 PM
llllllllll
IS - 1st Gen (2001-2005)
07-13-10 06:22 PM
