Squealing brake noise PROBLEM!!HELP!!
Old Jun 17, 2013 | 07:21 PM
tripperlex's Avatar
tripperlex
Angry Squealing brake noise PROBLEM!!HELP!!
MY is350 still squeals when i step on the brakes. Especially when im in reverse. After changing the pads and cleaning it with brake cleaner it still squeals..Can someone please Help ME!!!
Old Jun 17, 2013 | 09:28 PM
mong's Avatar
mong
Get the updated oem shim kit for the fronts and rears. Make sure you have your brake pads with it's low pad sensor facing the correct direction. Also don't put any anti squeal or grease on the front brakes. Only on the rear is needed and it should come with the rear shim kit. After I did that.. my stopped squealing. Good luck
Old Jun 17, 2013 | 09:42 PM
BigJ's Avatar
BigJ
^^ This, but also make sure there isn't a pebble/stone stuck in your caliper somewhere and it's grinding on the rotor. Look for odd wear marks on the rotors, that will tip you off. I had that happen to me.
Old Jun 17, 2013 | 10:34 PM
2genIS's Avatar
2genIS
read this.. most likely is your shim kit.. get a new revise one..
https://www.clublexus.com/forums/sus...squealing.html
Old Jun 18, 2013 | 10:58 AM
panda08's Avatar
panda08
you need oem pads/ rotors/ shim kit. did you replace the pads yourself with after market ones and not change the rotor?
Old Jun 18, 2013 | 10:23 PM
tripperlex's Avatar
tripperlex
Default THanks
Thanks for the help guys.. the mechanics from the dealership where i got the Lexus from changed the pads front and back. i dont know if its oem brake pads or not. DO ya have any idea how much shims cost?
Old Jun 20, 2013 | 10:40 AM
stanjohn12's Avatar
stanjohn12
Smile
I'm having the exact same problem. It squeals like crazy early in the morning while reversing.
But if I spray some anti rust WD 40 spray , the noise does not come for 2 or 3 days and then it comes back again. What could be the issue ?
The brake biting strength is still strong. How do I find out if the shims or pads need changing without having to remove my wheels?
Old Jun 20, 2013 | 10:47 PM
2genIS's Avatar
2genIS
You have to remove your wheels and brake caliper in order to find out.. But from your problem description.. sound like your are using the hold shim kits.. I think the new shims kit has a rubber material on the back of the shims (soft material kinda like)..
Old Jun 21, 2013 | 06:18 PM
Slammer1's Avatar
Slammer1
Remove the pads, pins and hardware. Apply caliper grease to the pins/slides, hardware where it contacts the pins/slides and the back of the pads. You should be good. I had this issue from the left rear of mine about a month ago and a quick clean and lube cured it.
ojotie
Jul 6, 2016 03:12 PM
mrjazz
May 24, 2015 03:30 PM
JDFelder
Suspension and Brakes
Apr 10, 2015 11:52 PM
seivonecsu
Apr 12, 2012 05:13 PM
