Do I need a camber kit?
Old Feb 9, 2013 | 08:39 PM
MonsterIS's Avatar
MonsterIS
Default Do I need a camber kit?
I'm going to run 18x9.75 +20 with 245/40/18 all around. Will I need a camber kit? What does a camber do anyways besides save me some tires? What's the purpose of it?
Old Feb 9, 2013 | 09:20 PM
RVCAis250's Avatar
RVCAis250
First off, you won't want to be running 245/40 tires on those specs. Way too aggresive of wheels to not be stretching tires. You'll also be needing to make fender modifications and even then you will need to allow for negative camber so a camber kit will not help you at all.
Old Feb 9, 2013 | 09:25 PM
MonsterIS's Avatar
MonsterIS
I got the wheels together from some local guy selling them. A camber kit won't be necessary then?
Old Feb 9, 2013 | 09:31 PM
Gville350's Avatar
Gville350
You could "need" them to run additional negative camber to clear the fenders. The fronts I'd be more worried about those with those tire size.
Old Feb 9, 2013 | 09:43 PM
MonsterIS's Avatar
MonsterIS
Which camber kits do I need? If I don't run cambers, will my set up still be okay? I'll need some major fender work.
Old Feb 9, 2013 | 09:51 PM
RVCAis250's Avatar
RVCAis250
True, but you'll clear in the rear. You need to roll the front and rear and relocate the front bumper tab. You won't need any additional camber other than what will naturally occur from your given specs.
Old Feb 9, 2013 | 10:08 PM
MonsterIS's Avatar
MonsterIS
What's the easier way to relocate the front number tab? If I don't remove it, will it rub on my tires?
Old Feb 9, 2013 | 10:15 PM
RVCAis250's Avatar
RVCAis250
Rub is a very soft way to put it. More like it'll eat away at your tire tread like it did mine. It took out like 1/4" out of my tire before I got to relocate them.
So there is no real easier way. You can either shave it away and use a quick release bumper mount to hold the bumper or just shave away and make a new hole further down. I did the second one.
Old Feb 9, 2013 | 10:43 PM
MonsterIS's Avatar
MonsterIS
I'm going to be lowered on Tein S-Techs. It won't drop the ride significantly but will I still need to move the number tabs?
sleekbrian
Suspension and Brakes
Aug 3, 2012 12:34 PM
bombermani
Mar 13, 2012 10:33 AM
JMcDonald
Dec 7, 2010 07:56 PM
handoverfi
Dec 17, 2008 09:59 AM
4onenight
May 20, 2008 10:45 PM
