Rotora big brake kit feels shakey
Old 11-30-12, 10:38 AM
peyman
peyman's Avatar
Default Rotora big brake kit feels shakey
1 month ago had my mobile mech install my rear rotoroa bbk, everything went fine
decided to let someone else install the front yesterday, the installer said the original owner had accidently mix matched the caliper brackets when he was using it on his car, so he swapped them to where they should be. after install was done, when applying more pressure than normal to the brakes it feels shakey and a bit unstable, the installer said because we swapped the brackets, now the brakes pads need to wear evenly and thats why thats happening and after a few hundred miles will go away....and if it doesnt to buy new brake pads (which i dont want to go through all this hassle if waiting a few hundred miles and buying new pads will not fix the problem)
does his explanation make sense? what would you do if you were me? just wait it out? he says to drive soft on them to avoid damaging the rotors
Old 11-30-12, 11:35 AM
Gville350
Gville350's Avatar
Mix-matched? Please elaborate.
Old 11-30-12, 12:18 PM
Sffd103
Fire Slayer
Sffd103's Avatar
Do you have the manual to verify if what he's saying is true? I had someone else install mine so I don't know if that's even possible or if they're labeled. I guess apply light pressure to the brakes to make it smoother. Good luck.
Old 11-30-12, 01:45 PM
peyman
peyman's Avatar
meaning the dirvers side caliper bracket was installed on the passanger caliper and vice versa which he then said he corrected
Old 11-30-12, 01:48 PM
peyman
peyman's Avatar
i dont have the manual and there isnt anything on the caliper bracket that says where it goes.
mariano, did you use brake shims on your kit? the brakes make some vibration sounds when slowly releasing the foot of the brake pedal
Old 11-30-12, 02:04 PM
Quik208
Quik208's Avatar
There should be part numbers on the brackets. Also if they are swapped it moves the caliper closer to the "2 clock" position when they should be at the "3 clock" position. I believe it changes the angle the pads bite the rotors a few millimeters difference. This could cause the pads to not bite square on the rotors.
Old 11-30-12, 02:08 PM
peyman
peyman's Avatar
mariano do you have the manual? can you verify the part #'s on the bracket so i know which one goes where?
Old 11-30-12, 02:09 PM
peyman
peyman's Avatar
so would you reccommend swapping the brackets again? or driving on the pads to wear them down a bit? or cant i have the pads swapped from drivers to passengers?
Old 11-30-12, 02:11 PM
Quik208
Quik208's Avatar
I should have the paper work on the set I have at home. If you want I'll pm you my number to talk. Probably easier then writing everything out.
Old 11-30-12, 02:12 PM
peyman
peyman's Avatar
that would be great thanks appreciate your help
Old 11-30-12, 02:13 PM
Quik208
Quik208's Avatar
Send over a pm.
Old 12-02-12, 11:48 PM
enrikito
enrikito's Avatar
i got a couple for you to check out and compare...
the design in my kit is slightly newer than yours but I'm not sure if they use the same mounting brackets or not...
I'll get back to you on PM on your other questions.
Old 12-03-12, 10:39 AM
peyman
peyman's Avatar
didnt know they had another design, thats beautiful. i guess i have the older kit
Old 12-03-12, 05:50 PM
peyman
peyman's Avatar
Enrikito have any pics of the rear? Curious to see what the caliper design looks like.
Old 12-04-12, 07:49 AM
enrikito
enrikito's Avatar
this is the clearest pic i have (my car is undergoing CSP work right now)
Quick Reply: Rotora big brake kit feels shakey
