***I've got NEW SWAY BARS***
Re: ***I've got NEW SWAY BARS***
Originally posted by BLiu
Hi Guys,
It's been a while since I posted - probably due to the arrival of my first newborn son...
Anyway, I just bought some sway bars from a new Lexus Aftermarket Products Company called Daizen through one of their distributers, TMEngineering. Apparently, from what Todd tells me this company is really serious about breaking into the Lexus aftermarket parts market by providing high quality, well thought out designs. For me, since Todd himself has such impeccable tastes I know the companies he refers me to should probably be the same. So I decided to give this product a shot and have Todd put them on for me. Here is a review - keep in mind I had the TRD Sways before so I can make a direct comparison...
First of all, the Daizen sways are a silver powdercoat finish which I find very nice and clean.
The rear sway bar is 3-way adjustable so that you can dial-in the exact amount of over/under steer you like! This is a definite plus over the TRD sway bars because they are NOT adjustable.
The front bar is hollow and is lighter than the REALLY HEAVY TRD front bar which reduces unsprung weight.
My bars also came with Urethane Bushings compared to the standard rubber bushings that TRD provides.
Here is my comparison with TRD with regards to performance:
The car turns and stops better than the TRD sways probably due to the difference in unsprung weight of the bars. Apparently, they really did their homework in tuning the front sway bar with the rear because handling is as good as with the TRD bars. The ride is better than with the TRD sways and, in fact, almost close to stock especially during straight driving. Turning stiffness/flatness is virtually identical to the TRD sways.
I really like the 3-way adjustable rear sway, especially for very finnicky drivers who want their handling dialed in a little more custom to suit their own tastes!
The price is competitive with the TRD sways.
That's my review. I am really excited because it looks like there are more things to come with this company and judging from the fit, finish, and performance of the sway bars, Daizen looks like a very legitimate Lexus aftermarket company which is great news for us because the market is so thin anyway!
Brent
Hi Guys,
Brent
Congrats on the newborn....I know hes a handful!
What did you do with your TRD sways??? Are you possibly selling?
Shoot me a pm and let me know.... Tiny
Thanks for the review... this is the first review I've read about the Daizen sways. I was holding out on purchasing TRD sways just to see if the Daizen's were better - apparently they are!
Can we do a group buy on the Daizen sways? Anyone down?
-Altaf
-Altaf
Re: Re: Re: ***I've got NEW SWAY BARS***
Originally posted by rominl
with the daizen, the bar itseld is less stiff, but the bushing is a lot harder which helps when you turn. however during normal unecen road drive, since the bar is less stiff, it allows a bit more flex between the left and right. taht's why the ride quality is better
any other input?
any other input?
I would think that all the bushing does is get the pressure to the bar sooner than the rubber one (because it compresses way less). Once it comes down to the bar itself, then only the bar stiffness should be a factor... May be I am wrong.
May be I will have to bum a ride from someone with these bars at the next CL meet. Actual drive is the final measure: all I've said up to now is my interpretation of a theoretical sway behavior. I was just hoping that my interpretation would match real life experience and so far, it doesn't.
Someone have a better theoretical explanation of this?
I'll throw this out... Perhaps there is a point where additional stiffness does not contribute to the flatness or control and only adds harshness to the ride and stress to the rest of the suspension components. So the idea is to get as close to this hypothetical point WITHOUT going over [sounds like a game show]. According to some, the TRD sways go way past that point so much that they cause undue stress and actual damage to other suspension components.
exclusive matchup
now this is my wild thought, but anything (even metal) they flex a bit. so yes the bushing is hard and not alow movement within the bushing area. however if the sway itself allows more flex, meaning you can "twist" it more than the trd sway, than that could make sense to the overall ride quality
I have the polyurethane bushings on my stock sways and I have to agree with Brent's statements in regards to the ride quality. The polyurethane bushings does help flatten out the car alot when cornering. However, it doesn't affect the ride comfort as much as I thought it would.
The car is more responsive to the road condition. I have written a review on the bushings itself after the installed.
here is the link........
https://www.clublexus.com/forums/sho...threadid=62453
I think I will get their sways as well after reading Brent's review.
Re: Re: Re: Re: ***I've got NEW SWAY BARS***
Originally posted by Vlad_Stein
OK, the part about the less stiff bar offering better ride quality makes sense. What doesn't seem to make sense is the fact that the polyurethane bushing makes the whole thing stiff in turns and soft on bumps.
It is softer on bumps in the straightaways because there is more flex in the Daizen sways than the TRD's. So a lot of the posters are correct in that assumption. The TRD bar is SOLID and it is THICK making it very harsh when it comes to normal ride quality. Keep in mind, that a lot of times when it comes to performance, overkill is the easiest thing to do BUT tuning is an art. The Daizen sways are matched better with the Polyurethane bushings to provide a better compromise between ride and performance. Therefore, when pushed in the turns the combination of the Polyurethane bushings and the sway bar performa as well as a STIFF TRD bar with rubber bushings.
For a better demo just try putting Urethane bushings on a stock sway bar and you can tell the HUGE difference alone in handling as compared to stock bushings. Now, add Daizen's matched front and rear sway bars and you get the total improvement including keeping the rear in line. THEN, on top of that, if you want a little more wiggle or a little more understeer change the setting on the rear - VOILA! One happy driver!
The rear bar is killer too with the dial-in capability of the three-way setting! (Can everyone tell I LOVE this feature?)
Hope this helps.
Brent
Re: Effect of bushings
Originally posted by dipstick
So does it stand to reason that if you got the Daizen set and wanted to soften it up a bit you could go back to the rubber bushings?
Brent
The TRD are very good and very high quality, but yes they seem to go beyond what is necessary, and as we all know, have damaged links and mounts due to their high stiffness.
The same analogy can be applied to most other suspension components. Tires, yes a plus 1 or plus 2 size will increase handling greatly, but after a certain point, the sidwall becomes so stiff (hypothetically say a 21" tire/wheel setup on a GS) that it begins to become worse for handling. Same with springs, shorter stiffer ones are better, but after a certain point, too stiff is no good.
The Daizen bars are able to allow for excellent handling with the good ride due to the matching of sizes with the vehicle and vehicle weight, and also the urethane bushings. Kajukenbo can definitely attest to this, I'm sure he was quite astonished at how much of a difference a simple bushing swap was and still being able to keep the stock bars. This had basically zero effect on the straight ahead ride, since the compliance of the left-to-right was not changed.
This is where the TRD bars fall short per se, as they have rubber bushings. They also would be even stiffer in turns if they had urethane bushings. This is why a bar that is roughly 15% softer can perform the same in turns, while still having compliance for straight ahead driving.
Unsprung weight is also one of the most critical issues with any vehicle. Ask anyone here with 19" or 20" wheels if their car accelerates, brakes or turns better than with the original 17". If they say yes, they are probably pulling your leg. Aesthetics are cool (and still necessary!), but you cannot escape the laws of physics. Sway bars that are solid are considerably heavier than hollow, which is one of the components that can have a very noticeable effect as far as unsprung weight goes.
Brent is pretty picky, I haven't seen him get this excited over anything for his car in a while now. He's even taken things OFF of his car just because they weren't exactly right, so I think his excitement is pretty genuine. It's definitely not a money issue either, his car is pretty spoiled as far as that goes It gets whatever it wants no matter what the cost.
Todd Matsubara
TM Engineering LLC
www.tmengineering.net
Thanks for the kind words rominl!!!
As always, let me know if you need anything for the car or if you have any questions...
Re: Re: Effect of bushings
You will lose some handling performance but you could do it that way if you like. Personally, I would not do it that way just because the whole goal for upgrading to a sway bar package is to get MAX performance with some minimal compromise in handling which the Daizen bars and Poly bushings will do. But that's just my opinion - others may feel differently.
Brent
Brent
