Hello,
Just purchased 99 gs4 past Sunday. I would appreciate any insight or suggestions to my question. When I am driving my GS4 , be it on highways or on local roads, my steering wheel would pull/jerk sharply either to left or right once in awhile
Is this a common thing? I have 17" OEM chrome wheels/Faulkin 235/45/17. If this is not common occurance, this is what I have checked so far. At first, I suspected a crowning or uneven local road surfaces but noticed this was happenning while driving on highways as well. I then checked tire tread and tire pressure for any problems but it checked out ok. I then had a local shop lift it and take a look under the car but nothing wrong can be found. Any ideas?
As for my GS4--Great car!! GS4's power reminds me of T/A GTA I used to have and the ride is unbelievably smooth (hell of lot better than Q45 I got rid of)
Is this a common thing? I have 17" OEM chrome wheels/Faulkin 235/45/17. If this is not common occurance, this is what I have checked so far. At first, I suspected a crowning or uneven local road surfaces but noticed this was happenning while driving on highways as well. I then checked tire tread and tire pressure for any problems but it checked out ok. I then had a local shop lift it and take a look under the car but nothing wrong can be found. Any ideas? As for my GS4--Great car!! GS4's power reminds me of T/A GTA I used to have and the ride is unbelievably smooth (hell of lot better than Q45 I got rid of)
I say it could be the road, and the tires and maybe your brakes. allignment is prob the biggest thing. I just found out the other day that i have a broken band in one of my rear tires, i was very happy about that. oh joy. But just get the basic things checked i suppose. I have to drive an hour or so to get my car alligned and balanced.
JacobT , Jyoo & Fireball- Thanks for your quick reply!!
I will have a local shop do the alignment and if that does not correct, then replace tires. (have at least 75% tread left
Thanks again.
)Thanks again.
rominl
exclusive matchup
close
- Join DateMay 2002
- LocationLovely OC
iTrader Positive Feedback100
iTrader Feedback Score(4)
Liked:494 Times in 358 Posts
either tire or alignment. i have the same thing too, thought it's alignment, did it and not helping. so it's tires
I just changed from Good year GT+4 to Michelin pilot sports A/S
.....wow....what a difference.....
quiet.....smooth....lots of grip and it feels like I am in BMW...
before changing the tires,, I thought I am in Camry...
tire makes big difference.....
it's like
one runs bare foot..
one runs with nike airmax...^^
it's like
close
- Join DateFeb 2001
iTrader Feedback Score(20)
Liked:4,054 Times in 2,760 Posts
The GS suspension and steering is very sensitive to tire changes it seems. The GS suspension is also easily knocked out of alignment. I believe the alignment and balance needs to be checked pretty much with every oil change.
ExploreLexus Champion
GS is prone to tramlining (tires following road ruts, grooves, etc). This is, to some degree, a tire issue but it also involves suspension design/engineering (that's not to say the GS has poorly engineered suspension, just that it can be a difficult problem to solve in cars with low profile tires). Careful alignment helps, higher tire pressures help and a different tread pattern can help.
And welcome to CL!!!
I have the same problem. I'm having them check out my suspension Tuesday since it is making some wierd clunking noises.
