TRD Components – New Find?
Old Oct 23, 2002 | 11:34 PM
rominl's Avatar
rominl
exclusive matchup
Originally posted by GS4Will
L/P, thanks for check into this:
Blue-race verison, front, solid, rear/hollow
white-street version, front/hollow, rear/solid
slightly different diameter too
btw, vvt-i, $300 is for the front only..
for the record, so what's the diameter of the trd race sways? now i know the street one is 31 front and 16 rear.
and it's weird why they don't just make the rear solid as well...
Old Oct 24, 2002 | 12:07 AM
GS4Will's Avatar
GS4Will
romi...go to the links in the last page and you will get all the good trd info
Old Oct 24, 2002 | 12:18 AM
rominl's Avatar
rominl
exclusive matchup
oh man i feel so embarassed... so it's 31 and 19
Old Oct 24, 2002 | 01:21 AM
Neo's Avatar
Neo
The One
I wonder too why both set has one solid and one hollow. I am not sure about diameter but does that mean the rear sportivo is beefier than the rear race?
Old Oct 24, 2002 | 01:31 AM
rominl's Avatar
rominl
exclusive matchup
not really, it's a lot of math and physics mechanics when they design it. the sportivo rear is 16mm solid, but the trd race rear is 19mm hollow.
in general the beefier the sways are, they better the handling and how it holds the car flat. however, too thick the sways you can easily lose control of the car once you go "over" the limit.
it could well be the case that the hollow 19mm has a stronger force than the 16mm, i wouldn't be surprised. moreover, the stronger the rear compared to the front, the easier it is for you to tail spin your car. everyone knows how easy it's to skid the rear of our cars. i bet that's why the front sways are so much thicker than the rear
hope this helps
Old Oct 24, 2002 | 01:35 AM
GS4Will's Avatar
GS4Will
agree...all of the TRD stuff are designed to work in sync...i alos noticed the same thing on other cars that offer factory sports pkg..often times only front or rear has BEEFED up sways...
Old Oct 24, 2002 | 01:36 AM
rominl's Avatar
rominl
exclusive matchup
yup, on my acura, the sways upgrade mainly upgraded the rear sways. i am sure there must be a reason
Old Oct 24, 2002 | 01:40 AM
Neo's Avatar
Neo
The One
I was just wondering since I already have the race sways installed. The rear is still a little touchy around corners.
Old Oct 24, 2002 | 01:59 AM
rominl's Avatar
rominl
exclusive matchup
touchy you mean not sticking to the ground? say when you make a right the rear right still got tuck up?
Old Oct 24, 2002 | 07:32 PM
GS4DOUGIE's Avatar
GS4DOUGIE
Default Please explain
Gents-
Could someone kindly explain the benefit of installing a front and rear sway bar?? In addition can someone do it in lay man's terms?? Brief examples of how the car handles with out sways, then the difference in handling when the sways are installed??
Pro's and Con's for a rookie-
Thanks-
Doug
Old Oct 24, 2002 | 08:55 PM
Neo's Avatar
Neo
The One
Here is a start:
http://www.howstuffworks.com/question432.htm
Old Oct 24, 2002 | 11:08 PM
rominl's Avatar
rominl
exclusive matchup
Default Re: Please explain
Originally posted by GS4DOUGIE
Gents-
Thanks-
Doug
umm, in short, the sways help to hold the left and right suspension together, so when you are making turns, the car will try to stay flat on the ground.
for example, imagine you making a hard right. during the turn your car will seem to have tilted left, meaning the right wheels will leave the ground, right? that's bad handling coz' you lose the grip from your right tires and the car tends to slide out more easily.
a perfect turn would be even at high speed the car stays flat and the right tires still grip to the ground perfectly. that's where sways comes in. it holds the left and right suspension, so when you are making the same right turn, the bar till try to hold the right wheel together and stay it on the ground.
the gs4 already has stock sways. however, as you might have guessed, the thicker and stronger (solid vs hollow) the sways, the better their ability to hold the suspension together.
however, having too thick of a car would make the car too hard to control, and would easy tail spin when making really fast turns. that's why designing sways is a pretty big thing just like making springs, etc...
Sub079
GX - 1st Gen (2003-2009)
Aug 8, 2005 11:08 AM
LasVegasGS
Apr 2, 2005 12:07 AM
PAULGS430
Apr 16, 2004 04:45 PM
Vlad_Stein
Suspension and Brakes
22
Jun 24, 2002 10:53 PM
Vlad_Stein
Feb 27, 2002 10:32 PM
