Sway Bar Link Tip
Old 01-02-12, 11:43 AM
lexusben
lexusben's Avatar
Default Sway Bar Link Tip
Hey guys. I'm currently trying to tighten back up my front Sway Bar Link. The problem is that as I try to tighten the sway bar link, the ball joint is spinning so I cannot get it tightened up. How can I get it tightened up since the ball joint keeps spinning?
I am trying to tighten 48820B At the bottom of the picture.
Old 01-02-12, 12:45 PM
02Legend
02Legend's Avatar
If I remember correctly you will need an allen key to hold it from turning while tightening it down.
Old 01-02-12, 12:47 PM
YviE
YviE's Avatar
^^ Correct, but for the rear links only. You should not have this problem with the front links, the design is different.
Old 01-02-12, 12:52 PM
lexusben
lexusben's Avatar
Thanks for the advice, sir. These sway bar links have been giving me trouble. The bolts that held the link to the sway bar snapped in half when I tried to take them off. Then when I put on the new Link and tried to tighten the upper stud (part of the link) to spec it snapped. Now I am going to use a bolt in its place until I get a new stud or full link. Lol, hopefully my luck will turn.
lexusben
lexusben's Avatar
Hmm, I am working on the front links.
Old 01-02-12, 02:06 PM
lexusben
lexusben's Avatar
Never mind, guys. Just had to use a wrench on one end until it was tight enough, then we were able to tighten it up from the one side.
Old 01-02-12, 02:41 PM
02Legend
02Legend's Avatar
Glad you got it worked out. Sorry If I caused any confusion about the "allen key" thing. I was thinking of when I had my IS300. I went and looked at the news links I ordered for the GS and was going to correct my post, but I see you got it fixed.
Old 01-02-12, 03:13 PM
sakataj
sakataj's Avatar
how much were the OEMs? you probably could have just bought some FIGS front sway bar mounts....(left parts in the picture)
the OEM REARS on the gs DO use a allan wrench key,i replaced mine with FIGS rear sway bar which no longer uses a allan wrench
Old 01-02-12, 03:58 PM
PHML
Master Thread Closer!!
PHML's Avatar
how much were FIGS' sway bar endlnks?
Old 01-02-12, 04:35 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
http://shopfigs.com/v1/index.php?rou...&product_id=85
Old 01-02-12, 08:18 PM
lexusben
lexusben's Avatar
These are actually Moog Sway Bar Links. The OEM's cost more than FIGS. I would have bought FIGs but I'm only dropped an inch on springs and I just don't really have a need for them.
Here is the Picture of the Passenger Side Link with the stud still intact:
And here is the Driver Side where the stud had to be replaced with a bolt:
Old 01-03-12, 11:29 AM
sakataj
sakataj's Avatar
dunno what i paid for them its been awhile and they were one of the first sets out to "test"
dont forget the rears
http://shopfigs.com/v1/index.php?rou...&product_id=80
if they were cheaper to buy the FIGS ones i still would have bought the FIGS ones then....regardless of how low you are
Old 01-03-12, 02:14 PM
lexusben
lexusben's Avatar
The Moog's were only $25 a piece. If they go bad I will definitely step it up to FIGS but the Moog parts looked like they were of decent quality.
Old 01-03-12, 02:35 PM
Lextasy671
Lextasy671's Avatar
glad you resolved your tightening issue. i have plans to buy FIGS parts as well.
Old 01-03-12, 02:38 PM
PHML
PHML's Avatar
I just bought Moogs as well...all 4 corners...if they last 1/2 as long as my OEMs...I'll be a happy camper. OEM lasted 10+ years.
Quick Reply: Sway Bar Link Tip
