More low
Old 11-21-11, 08:07 PM
VIS250P
VIS250P's Avatar
Originally Posted by laobo979
VIS250P your ride looking sicc with the new setup . But is that tape on your rear fender?hahaha...
YEa I use tape to cover the bondo crack... Ugh I gotta take it to body shop again
Old 11-21-11, 08:24 PM
EZwider
EZwider's Avatar
Originally Posted by Sffd103
Well, I scrape the floor on the freeway at high speeds when I hit a dip only cause I have the F Sport chassis brace. I only rub a bit up front cause my fender liner is torn through. The rear is o.k. cause I have the camber but the tire is kinda touching the sidewall up against where the bumper meets the quarter panel. what size are your tires? I refuse to do the flush/poke look cause I already had one fender fixed. I'm not into that. I'm more old school and like to tuck.
Front - 245/30 Rear - 285/25. Not really going for that hella flush look, I still need a fully functional car. But I want to close the gap between wheel and body as much as possible. F-Sport springs are just about a 1'' drop. Does Megan do a 1.5? or only 1.25.
Ill post a couple pictures tomorrow.
Old 11-21-11, 09:32 PM
Sffd103
Fire Slayer
Sffd103's Avatar
The Megan coils go as low as you want and as high as stock. Those tires are too wide to be able to slam your ride and think you'll run into some problems. I have my front and rears rolled and have 225/30/20 and 255/30 20 tires. I'd hate for you to have to get new tires, but that's the only remedy I see to go lower without having issues with rubbing.
Gsmerwan
Suspension and Brakes
04-18-15 11:47 AM
Lokz
32
03-24-14 12:15 PM
lol89
01-21-14 08:18 PM
stan727
12
08-28-12 08:48 AM
panda_ek9
18
05-03-09 11:45 PM
Quick Reply: More low
