springs not even now
when i lowered my 99 gs300 last wensday. the car wasnt level right to left. the drivers side is 1/2" higher in the front and 1/4" in the rear. i thought it might just have to even out when first driven. but it didnt.
and aslo having steering wheel shakes at 40 and 65mph. and got worse after i balanced the fronts again. also it sounds like the wheel bearing on the drivers side is going (humming sound) but no play in the bearings. i will be getting the camber arm bushing kit fron daizen. and also new shocks soon. i dont want to get and alignment till i get the shocks.
any thought on the not being level? checked the spring on the lift and all is seated good. nothing out of wack that we could see. spring are new tein cs.
are the shocks/struts new or used? Did you check them before putting them in? i hope you did. piston shaft travel should be smooth. faulty units tend to stick even freeze at different points during travel. If you can rule this out i would move to suspension components. a faulty body will cause sag
ilshm113
09-14-14 11:34 PM
