Need Upper Control Arm
Old Jul 26, 2010 | 12:41 PM
jeromekim's Avatar
jeromekim
Does anyone know what size socket I'll need to remove the upper control arm?
Old Jul 27, 2010 | 07:51 AM
JiBBeL's Avatar
JiBBeL
Well... you'll need a couple. a 14, a 17, and a 19 (3/4").
Old Jul 27, 2010 | 11:58 PM
toy4life86's Avatar
toy4life86
any luck on that oes part being orignal?
Old Aug 21, 2010 | 07:29 AM
jjbenzo's Avatar
jjbenzo
So I have now replaced the upper control arms, lower ball joints, sway bars and their bushings along with outer tie-rods. I still have a creaking noise coming from the front end when going over bumps and driving slowly. What els is there that could be causing this? I have not replaced outer sway bar links, trailing arms or lower control arms. Any other ideas as to why I can't get to the bottom of this creaking noise? Could there be bad steering rack bushings? I know that I am needing to replace both engine mounts, but that would cause more of a vibration, not a creaking noise correct?
Old Aug 22, 2010 | 06:08 PM
toy4life86's Avatar
toy4life86
did you change out the caster arm bushings the big ones?? thats probably the creaking
Old Aug 23, 2010 | 07:45 AM
Gunnut's Avatar
Gunnut
I have new UCA's and caster arms on order. My front end has squeaked for the past three years. I've replaced the struts, ball joints and tie rods in the past year. DOing a brake service the other day I checked for play in the upper ball jiont on the left side. There was quite a bit of play so it is time to change them out. I'm thinking the ball jiont may be the problem but am going to change out the caster arms with new oem just because I doubt they've been changed before. I bought the car with 90k on it a little over 3 years ago. It has 172k now.
I've also serviced the sway bar bushing with no positve result. If this doesn't work, I'm left with strut support or LCA as the culprit.
Old Aug 23, 2010 | 08:39 AM
jjbenzo's Avatar
jjbenzo
The dealership told me while I was in getting the upper control arms installed that my "trailing arms" should be replaced next. I believe Lexus refers the trailing arms as the same thing as the caster arms. Is it safe to assume that new trailing arms/caster arms come with new bushings?
Old Aug 23, 2010 | 08:57 AM
Gunnut's Avatar
Gunnut
They do. Unfortunately Lexus does not sell replacement bushings, only the entire assembly. I want the stock ride so no Daizens for me.
Trailing arm=caster arm
Old Aug 23, 2010 | 09:18 AM
toy4life86's Avatar
toy4life86
when i did my suspension
just last week the Caster arm was the only bushing that was bad, when i had everything unhooked and moved the hub up and down it was creaking, I replaced that bushing with a daizen I left all the others stock I dont think One daizen bushing is going to make the ride that much harder if i did all of them it probably would but the upper and other bushings seemed fine even the steering rack and sway bar bushings looked just like new.
My upper balljoint is just OK....
my tie rod was bad i replaced those as well because i didnt do it when i did my Lower ball joint.
but yah Id say its the caster arm, and yes the new one would of course come with a new bushing already in place
adamhaver
Feb 15, 2018 01:51 PM
UseeF20
May 22, 2014 04:55 PM
RoMiLex
Suspension and Brakes
Jan 11, 2014 08:33 PM
djspawn00
Aug 28, 2010 06:50 PM
sputniknyc
NELOC
Jul 24, 2010 12:27 PM
