SPC upper control arms = waste of money
Old 07-23-11, 01:42 AM
  #46
revel
revel's Avatar
with OEM UCA and BC coils i am already smacking the top of inner wheel well on big dips. was hoping aftermarket UCAs would help fix this, but no i dont know.
sidenote: i see the 1st gen BG GS in previous post. BG has nice styling.
Old 07-23-11, 10:41 AM
  #47
AKS14
AKS14's Avatar
Yeah, I work with BG and did the 5spd swap with him.
And regardless of if its an aftermarket or OEM UCA, its going to hit the inner well if you are low, if its an aftermarket arm its still in roughly the same position and will have the same amount of travel and come in contact with the wheel well.
Just get a whole saw and cut the well out and notch the body slightly around the strut tower above the UCA
Old 10-13-11, 09:42 AM
  #48
Anthony
Anthony's Avatar
Has anyone whos actually pretty low running these? Its been a few months since this threads been updated so just want to know if anyones bit the bullet.
The way i had my front i was running -4.5 degrees of camber and obviously as my daily tires were getting too costly. Ive cut out a hole for my UCA's to travel without hitting but just want to know if anyone's running these tucking more than half the tire up front. I do have custom fab'ed RCA's which i can remove if need be. Id be happy with +1 degree of less negative camber LOL..even though these say up to +2. SPC hasn't been online in about a year so, any help or about your setup with these would be much appreciated!
Old 11-10-11, 10:08 AM
  #49
Cuban GS
Cuban GS's Avatar
i have been running these for a few months and they are still running fine! if your goal is to ride low all the time i suggest having the knuckles chopped by atleast an inch so that the ball joint doesnt bang or protrude through the strut tower. i did find that the adjustment on the arms were minimal so i had them notched further a bit.
here is my static drive height. in this clip i was on the way from LA to SD.
http://www.youtube.com/watch?v=BpEjx...ure=plpp_video
Old 11-18-11, 11:31 AM
  #50
ElitistK
ElitistK's Avatar
Originally Posted by eyecon7
Bump I dont have RCA but when I installed these and new caster arm bushings it raise my car, Also My camber it about .02 but there is a steep angle I wanna go lower, and can I with RCA's?
Here are some pics with my coils maxxed out and the car sitting on the ground.
Take a die grinder, belt sander, and a hole saw; some of the metal in the wheel well has got to go.
You could cut the banana steering arm short, but then you run the risk of ubj hitting the tire, which means you either have to run effective low offset, or smaller overall diameter to clear it.
If the ubj cannot flex that much, the wheel motion/camber gain could get a little excessive with the uca at that angle. However, it is still not as bad as the LCA coming above the horizontal axis. Even with adjustable lca, many profesionally prepped cars still run rca blocks.
Old 11-21-11, 08:32 PM
  #51
lexusben
lexusben's Avatar
So the point of this thread is that the 2nd Gen GS is not meant to be slammed. And if you must slam it your going to have to look into cutting a hole in the wheel well, and finding a UCA that will accommodate to the awkward angle.
Old 11-21-11, 09:59 PM
  #52
redgs300
redgs300's Avatar
Is it normal for ONE control arm to have play while the other has no play at all?
Old 11-28-11, 10:05 AM
  #53
YviE
YviE's Avatar
I would guess that something else is wrong. Unless you re hitting potholes on only one side.
Old 11-30-11, 04:29 AM
  #54
TRBOSQRL
TRBOSQRL's Avatar
dam from the post it seems some of you guys think that the Lexus brand can be turned into mini trucking. be realistic if you want to ride low cut your spindles
Old 02-08-12, 01:30 PM
  #55
bluwagun
bluwagun's Avatar
Bbftd
If you cut the spindles wouldn't that make the uca ball joint closer to the wheel?
Old 02-09-12, 05:02 AM
  #56
YviE
YviE's Avatar
^^ I don't think that's a problem as long as it's not hitting the wheel/tire.
Old 02-09-12, 07:29 PM
  #57
bluwagun
bluwagun's Avatar
True, I guess it depends what offset wheels you would be running as well
Old 02-11-12, 07:42 PM
  #58
randee973
randee973's Avatar
u guys just made me 2nd guess installing my megan ez;s sheesh !!! i just want to lower mine 2 inches in the front and 1 in the rear sounds like ima have a headache.. or is it just for the real lowww look ?
Old 02-12-12, 05:17 PM
  #59
850Lexus
850Lexus's Avatar
That would be a bad ball joint if you have play.
Old 02-27-12, 09:16 PM
  #60
GS714
GS714's Avatar
Default SPC vs the OEM price wise
I shouldn't be expecting any problem if I just want to replace my 11 years old upper control arms with a pair of S.P.C upper control arms at stock height? Since it would cost me around $650 at Sewell. Its pay to shop around.
Quick Reply: SPC upper control arms = waste of money
