SAGE Front RCA (30mm)+LS400 Calipers+15mm H&R spacer+16" Stock Wheels = NO RUBBING!!!
Old 02-12-11, 05:17 PM
PHML
Master Thread Closer!!
PHML's Avatar
Originally Posted by lexusscturbo
Question, when you installed the LS400 BBK did you need to cut any of the dust shield off?
No need to cut...I just bent/folded the shield....this is to allow the LS400 caliper to be mounted.
Pete
Old 11-29-11, 11:17 AM
kamlung
kamlung's Avatar
does this also apply for the EXACT RCA? i would figure they are the same as SAGE?
Old 11-30-11, 11:07 AM
PHML
PHML's Avatar
No...if you running EXACT RCA....you need 17"+ wheels to make it work. The reason is because the EXACT RCA is larger....38mm.....versus the SAGE 30mm RCA. The extra 8mm will cause the it to rub against the 16" inner wheel barrel...thus, the need to have larger wheels. The same goes for the SAGE 40mm front RCA.
Pete
Old 11-30-11, 11:14 AM
kamlung
kamlung's Avatar
damn!!! so i guess i need to find some used SAGE ones then... don't see any new ones anymore?
thanks Pete
Old 02-13-12, 11:13 PM
PHML
PHML's Avatar
currently, this is my setup....on SAGE coilovers...with 18mm front RCA...and 30mm rear RCA....stock 16s + 15mm hubcentric spacers...and LS400 bbk.
Old 02-14-12, 08:01 AM
850Lexus
850Lexus's Avatar
thanks Pete
Check out Figs. He makes them and can make any size you want at a very reasonable price.
Old 02-14-12, 09:08 AM
sakataj
sakataj's Avatar
true, he makes them standard in 17mm and also any size needed
http://shopfigs.com/v1/index.php?rou...&product_id=90
Old 03-23-12, 10:47 PM
PHML
PHML's Avatar
doesnt figs sell them for like $200 or something around that amount? kinda pricey.
Old 04-18-12, 08:48 PM
AirRideFan
AirRideFan's Avatar
Guess this answers my question about your spacers !
Are they the entire 'adapter', with the studs on them? Where did you buy them? I'm gonna need a set of them ASAP, as well! GREEEEAAAAATTTTTT!
Old 04-20-12, 09:10 AM
PHML
PHML's Avatar
NO...I am using the H&R spacers in which I had to remove the stock wheel studs and install the longer studs. If you are running the same wheels as me...then you will need them. Every wheel is different, so do some homework before buying the wrong spacer size.
Old 04-20-12, 12:47 PM
AirRideFan
AirRideFan's Avatar
Oh okay... Are the H&R spacers Hub-centric? If not, I'm just gonna buy either 15 or 20mm adapters. That tough thing is, once it's SLAMMED on coilovers, I might have to remove those nice trim pieces on the inside of the front AND rear fenders and roll them to ensure the fenders do NOT rub my tires.
...even with just 245's. What do you think? 20mm is REAL close to a full inch, that the wheels/tires would be pushed outwards. Not sure if that will rub the fenders or not...
But, THANKS for the info bro.
Old 04-25-12, 11:51 PM
PHML
PHML's Avatar
I believe all H&R spacers are hub centric....except for the 5mm.
Only you can be the judge on what size you need....we don't know how much spacing you have with your current wheel sizes and offsets.
I suggest you get your coilovers installed....get to the desired height....then shave/roll your fenders. If you want a rear camber kit, get that installed too. Only then will be know what spacer size you need to push your wheels out to get as flush as possible.
Old 02-07-16, 09:08 AM
97-SC300
97-SC300's Avatar
So you just need 15mm spacers on those stock 16's to clear the LS4 BBK up front?
Old 02-11-16, 10:18 PM
takashi
takashi's Avatar
ah, I guess I have the 40mm SAGE RCA since it ate up my stock 16s when I put it as a spare fml
Old 02-16-16, 07:20 PM
kamlung
kamlung's Avatar
yes... i have this setup on my car... but you will need wheel spacers as well
jwynn
05-17-16 02:34 PM
joliroger4
Suspension and Brakes
15
10-20-14 11:49 PM
SOLID300
Performance & Maintenance
05-13-11 09:40 AM
rustednail
20
04-19-09 12:38 AM
jmack5150
21
02-20-07 07:05 AM
Quick Reply: SAGE Front RCA (30mm)+LS400 Calipers+15mm H&R spacer+16" Stock Wheels = NO RUBBING!!!
