front suspension fixes and facts
The GS has no caster adjustment anyone who said they worked on it is lying to you . The only way to get it in spec is to have a working bushing . Once it is dead ,it out out of spec and replacement is the only fix.
It runs from the lower control arm backwards to under the firewall.
I am speaking psgr side of car
tried that too but its tough to sell a car that test drives like its got a flat at 80km/h. Even though its all brand new underneath nobody wants a car that shakes "just because".
Hey everyone, instead of starting a new thread I thought I would just post here. I have a GS300 with 110,000 or so miles on the odometer.
I recently got my GS serviced (September) and they said that the suspension looked fine. They did a full inspection. Well, everything seemed fine until the last couple days when I would either be stopped or driving slowly and turning the wheel. When I would turn the wheel this HORRIBLE creaking/clunking noise comes about. It sounds just like the terrible noises in these videos:
http://youtu.be/IxtMFp6za-I
http://youtu.be/V8R54Me4oLM
The mechanic said my ball-joints looked fine when they inspected it. What should I do? Bring it back and tell them to look at the suspension again? Or is this something that someone can put a finger on right now, or at least lead me down the right track?
Thanks!
Thanks!
Your ball joints can "look" fine but be on the verge of catastrophic failure. I'd replace them now. My first replacement looked good until I removed the boot/cover. Metal shavings everywhere!! Didn't move freely at all.
They're cheap. You'll sleep better if nOthing else, even if it doesn't fix your problem. I bet they will.
Any fixes for this?
Has anyone had this problem? And does this mean its time to install those polyurethane bushings on Control Arm No.2? Or could it be something else? I really need to narrow this down instead of buying random parts and hoping it would solve it *facepalm*
Thanks
Car - 1998 Lexus GS400 213xxxKMS
HERES THE VIDEOS
You'll hear the sound consistently
Part 1
http://youtu.be/wjIkXKW4isQ
Part 2
http://youtu.be/_35mLzWeGS0
Thanks
HERES THE VIDEOS
Part 1
Part 2
soo......if ones suspension creaks HEAVILY with the slightest turns of the wheel at no to low speed, is that rack and pinion bushings? only reason I ask is now that I even barely touch the wheel at a stop or turning at any speed, it creaks louder than hell and can be heard clearly from the drivers side front. There is no clunking of any sort, just straight CRRRREAAAAKKKKKINNNGG. Sometimes in traffic....i'll make beats out of it since I know everyone is looking at me anyways.....
Parts order but not installed:
Moog LBJ's
MOOG outer/inner tie rods
Dorman UCA's
Parts i'm going to order on the 1st from sewell:
Steering rack bushing set (or go daizen????)
Front trailing arm bushings
Moog LBJ's
Dorman UCA's
Moog LBJ's
Dorman UCA's
Moog LBJ's
Dorman UCA's
Moog LBJ's
Dorman UCA's
Moog LBJ's
Dorman UCA's
Thanks for all the info on these...i will be ordering them very soon and installing them in couple months when i get back to the states from med school! very excited to see how stiff the front end will be compared to what it is now. for me, the stiffer the better because i ride 2" off the ground and this will help in anyway possible. So, BIG THANKS!!!!
