You mean for the sway bar brackets? I'm sure there is a torque spec but if I remember correctly they (the brackets) just bottom out to the chassis when tight. So as long as they are tightened enough to keep from loosening they will be fine.
Thanks, I installed Daizen sways Friday night and Sat night I started hearing this clunk on my pass side suspension/engine bay area. It reminded me of a blown shock but not quite the same clunk. I'm thinking more grease and loosen brackets.
You shouldn't need to loosen the brackets. A clunk is usually a sign of a loose bracket already, if anything I would make sure the brackets are tight and the bushings are situated correctly and not twisted.
