Line Lock (roll control) with anti lock help
From: Sideways on the Yellow Brick Road! < Thats KS!
OK, here is the deal. I was fixing to put a line lock sylinoid on my SC when I realized I might have a problem. You are supposed to put the sylinoid in the front brake line coming out of the master cylinder.
The problem is it feeds to a distribution block for the antilock brakes. I am worried this didtribution block will dump fluid from the fronts to the rear. Can anyone confirm? If it does then the only way to make this work is to remove the antilock brakes which sucks or buy two line locks and put them on the lines after the Block.
If I go with two I am sure I will get some sort of light on my dash when I use it. Any ideas? Has anyone done this?
