worn out brake pads
Old Jan 8, 2008 | 11:00 PM
ndk83's Avatar
ndk83
Default worn out brake pads
my brake pads are completely worn out, my appointment at lex to get them changed and rotors machined is next week (earliest they could fit me in) , how badly will i damage my rotors if i keep driving?? i can hear a slight scraping sound now when i apply the brakes. is it ok since im gettnig the rotors machined? or will i cause irreparable damage?
Old Jan 8, 2008 | 11:04 PM
gizbx4's Avatar
gizbx4
you have time.. mine were grinding bad and my service manager told me i could drive alot longer... as for the rotors.. youre going to need a new set
Old Jan 8, 2008 | 11:07 PM
ndk83's Avatar
ndk83
Wait If I Have Time Why Do I Need A New Set Of Rotors Then? Machining Wont Do Anything?
Old Jan 8, 2008 | 11:10 PM
z4frosik's Avatar
z4frosik
na not really, you could probably go a couple of months with that grinding, its just more damage to the ears then to the rotors.
Old Jan 8, 2008 | 11:20 PM
ndk83's Avatar
ndk83
Ok Good I Was Worried, I Only Drivin The Car 20,000 Kms (~ 12,000miles) And Eventhough I Drive(and Therefore Brake) Aggressively I Havent Had The Car That Long
Old Jan 8, 2008 | 11:51 PM
2slow's Avatar
2slow
How many miles do you guys have? i have like 14k and i'm going to need to change my brake pads soon.
Old Jan 9, 2008 | 12:43 AM
IS_NIICE's Avatar
IS_NIICE
i killed mine at around 9k. i got my rotors turned though, however next time i will need to replace them. i am at the absolute minimum millimeter length on the rotors right now.
Old Jan 9, 2008 | 01:31 AM
ndk83's Avatar
ndk83
yea mine were about wornout at 9k miles, now its beyond that. scraping and all these effed sounds are being produced everytime i brake
Old Jan 9, 2008 | 07:47 AM
Bichon's Avatar
Bichon
Does our car have an indicator, either audible or an idiot light, to signal the need for pad replacement before the rotors are damaged?
Old Jan 9, 2008 | 08:42 AM
IS_NIICE's Avatar
IS_NIICE
yeah, there is a little metal piece in the brake pad that will start to touch the rotor when the pad is worn down enough. when that starts happening, id say around 1k left? maybe 2
Old Jan 13, 2008 | 07:51 AM
Bichon's Avatar
Bichon
Thanks. Glad I didn't wait to hear it, though. I changed my brake pads yesterday at 26,000 miles. The squeaker is only on the inside pad, but my outside one wore a bit faster, and looked like it only had enough material left to last a few hundred miles before chewing up the rotor. Inside pad was worn too, but I'm not sure it's squeaker would have started singing in time to save me.
Old Jan 15, 2008 | 06:53 AM
shaolin's Avatar
shaolin
are you talking about front brakes or rear?
I replaced mine at the dealer warranty at 36k on IS350 with 25%left.
Same thing on the IS250 at the same mileages, but 85%left.
We are still running our rear stock brakes but wonder how long they will last.
Old Jan 15, 2008 | 10:07 AM
Bichon's Avatar
Bichon
In my case, front.
Brake pads are considered a wear item and are not usually covered by the warranty, so I assume you got them replaced with the low dust pads under excessive dust TSIB?
Old Jan 15, 2008 | 10:35 AM
shaolin's Avatar
shaolin
^yes, you are correct.
peehole813
Suspension and Brakes
Oct 10, 2010 02:02 PM
Healthy
Jul 21, 2010 01:06 PM
TokerIS350
Jun 22, 2010 06:46 AM
jimmysc3
Mar 7, 2010 06:07 PM
slk_dds
May 19, 2007 06:40 PM
