I have 20 inch rims on my car and the front two wheels are almost touching the spindles on the upper control arm ( V-shaped looking thing attached to body), please correct me if I'm wrong. It barely rubs, only going up driveways or full turns.
I'm planning on dropping it with Tein CS Coilovers, will this be an problem and make it worse when I lower the car? Thanks for your help.
The formula for calculating offset is the overall width of the wheel divided by 2 equals the centerline. The centerline value minus the backspace dimension equals the offset.
remember to convert from inches to milimeters.
