Alignment goes bad after a month
Old 05-29-07, 02:38 PM
iposthere
iposthere's Avatar
Default Alignment goes bad after a month
My problem is I get my alignment done, then in a month my car is shaking and pulling to the right. So basically I’m back at the shop getting my alignment fixed. They cant figure out why it gets messed up so fast. I don’t drive hard at all, I really only freeway drive it about 3 to 4 times a week. Any ideas on what might be causing this problem?
1998 GS300
1” Eibach springs
18” wheels
Thanks for the help!
Old 05-29-07, 02:40 PM
GSteg
GSteg's Avatar
What shop did you take your car to?
If your bushings are really old, that's the problem. No matter how many times you get an alignment, your spec will be gone because of the bushings.
Old 05-29-07, 02:53 PM
lexforlife
lexforlife's Avatar
1998 GS300
1” Eibach springs
18” wheels
have the shop check the rear toe ecentrics, the bolt tends to get worn over time and will not hold solid toe espically the outer nut . the rear settings directly affect your front toe so it does throw off everything
Old 05-29-07, 05:19 PM
iposthere
iposthere's Avatar
I took it to TirePros, they did the laser alignment. I'm going to take it to another shop, but i wanted to have a few ideas of extra things to have them check so I can finally drive my car again in peace.
Thanks for all the help so far!
Old 06-23-07, 05:17 AM
V300Graham
V300Graham's Avatar
Any more news on this problem ?
Old 06-23-07, 05:51 AM
josephdoc
josephdoc's Avatar
1998 GS300
1” Eibach springs
18” wheels
I think you should stop to go to that shop where you got alignment done last time because they did not tell you possible front end damages in your car. Without good front end condition, the alignment can be done but will not last long.
Old 06-24-07, 12:10 AM
L3XOTIC
L3XOTIC's Avatar
It seems like theres alot of alignment issues after lowering a GS...
Old 06-26-07, 05:49 AM
Chenzo26
Chenzo26's Avatar
There are all sorts of alignment issues whenever you lower ANY car. I don't know if this is applicable on a GS since mine is not lowered and has stock rims, but on my '97 Altima that was lowered, I had to get a camber kit just to get a decent alignment job. Personally, I'm done messing with the suspension and wheels. My '99 GS4 looks fine without being lowered, and it is so much less of a headache when you don't have to fix your alignment every 5 seconds.
PhantomV
10-13-14 11:43 AM
irokdastar
06-10-11 03:04 PM
SptDsgnGS
06-24-09 06:04 PM
kyoso23
Southwest
18
10-28-08 06:10 PM
Wald GS
Pacific
16
01-21-04 10:54 PM
Quick Reply: Alignment goes bad after a month
