PLAESE HELP "Daizen Sway bar"
Old Sep 17, 2006 | 08:57 PM
nhanphat's Avatar
nhanphat
Default PLAESE HELP "Daizen Sway bar"
I just installed the Daizen sway bar this morning, I have no problem with the front , but the rear it look like a inches longer and stock bar , there it no way that I can put it in place of stock . the end link will touch the spring ... Any body have this kind of problems? There are three hole at the end of the bar, with one it the right for stock suspension? Please help . Thanks.
Old Sep 17, 2006 | 09:07 PM
GSteg's Avatar
GSteg
You're suppose to reverse the endlinks. Flip it around. The instruction also says to reverse the endlinks.
Old Sep 17, 2006 | 09:16 PM
nhanphat's Avatar
nhanphat
Thanks for the quick reply. I will do that tommorow. For the adjustable what hole that you guys recommended? Thanks so much
Old Sep 17, 2006 | 09:18 PM
GSteg's Avatar
GSteg
Depends on your setup and preference. If you have staggered wheel setup, go with the oversteer hole so it'll help neutralize the understeer increase you get from the staggered setup.
If you have all the same width for rim/tires, then leave it in the middle, unless you prefer more understeer, then set it to understeer.
Torqueless
Suspension and Brakes
Oct 26, 2014 06:11 AM
toxikkobk
Feb 7, 2012 06:11 AM
benbuilt4u
May 28, 2011 07:09 PM
TopDown
Feb 19, 2010 11:50 PM
Frankdorn
Feb 7, 2009 06:59 PM
