Replacing VSC/ABS speed sensors
Apparently, when I put in my Tein CS suspension the speed sensors got cut later on that day.
Has anybody fix this problem and how much did it run?
The dealer did not want to fix it because they say it will be a recurring problem and charged me $100 for my trouble. Needless to say I won't be going back to my dealer again.
Is is going to happen again and is there any remedy?
Thanks guys.
Thanks guys.
Originally Posted by rgarjr
This is actually a common problem when doing struts replacements. You have to be careful with that wire. I know its not cheap. How did it get messed up?
any progress to report (on the replacement wire from Carson Toyota)?
My wife just had the L-tuned springs & shocks installed yesterday and reported that the VSC kicked in a couple of times driving home when she went around some mild turns in the road.
I'm curious to hear/learn if the speed sensor can be permanently damaged or if this just a temp issue until the ECU is reset.
Try disconnecting the battery for a few. You may have to get the codes cleared off.
