E-brake light problem
Old Dec 28, 2005 | 06:16 PM
PsiQo1's Avatar
PsiQo1
Default E-brake light problem
I think this would be the right place to post this. Move mods if im wrong. The problem im having is when i downshift or when i shift really hard or fast my e-brake light comes on for a second (or a few) but the e-brake itself isnt moving and i've tested it by holding it down after shifting and even had my cousin shift while i held it with my right hand and it STILL comes on...what could be doin this??..thanks
Old Dec 28, 2005 | 06:28 PM
TMaxxTim's Avatar
TMaxxTim
Check your brake fluid, the light will let you know when you're low too.
Old Dec 28, 2005 | 06:37 PM
PsiQo1's Avatar
PsiQo1
i checked my brake fluid its full..unless i got a new leak within a week..EDIT: thanks...any other ideas??..
Old Dec 28, 2005 | 11:33 PM
ted17's Avatar
ted17
same thing happens to me.....
Old Dec 29, 2005 | 04:21 PM
vredniykot's Avatar
vredniykot
i'd check for loose wire(s)
try thumping around the e-brake handle and console around the shifter
btw, is it auto or 5speed?
Old Dec 29, 2005 | 04:29 PM
PsiQo1's Avatar
PsiQo1
5 spd..if i hit the area around the e-brake and it doesnt do anything..what exactly would i be lookin for in wires?...loose?
Old Dec 29, 2005 | 06:58 PM
vredniykot's Avatar
vredniykot
loose like not clipped together very well or soldering came apart in the wire or wire rubbing on bare metal (vibration) and rubbing through the shielding
most likely what you got there is either a intermittent short or a sensor going bad
that's what i'd think if it was my car
if you can wait and see if anyone else put's their 2 cents in, maybe i'm wrong
i'd hate to have you tear up the center console for nothing
Old Dec 29, 2005 | 08:28 PM
PsiQo1's Avatar
PsiQo1
yeah i will wait til i get more input b4 i go rippin stuff apart..hopefully someone has had this happen to them and be able to fix it...its not really important ( i think) just kind of annoying to see the "BRAKE" light come on when you shift..
Old Dec 29, 2005 | 08:44 PM
ARISTO 161's Avatar
ARISTO 161
is it your traction going off?
Old Dec 29, 2005 | 09:26 PM
PsiQo1's Avatar
PsiQo1
5spd..no trac control
Old Dec 30, 2005 | 11:50 PM
PsiQo1's Avatar
PsiQo1
daym..i was hopin i didnt have to rip stuff apart...out comes the center console..ill let you know if i find anything..btw i wont be rippin nothing apart til AFTER New Years...
Old Dec 31, 2005 | 11:52 AM
sc1jzgte's Avatar
sc1jzgte
yea i have a 5speed and i got the same problem. it started out jsut when i shifted really hard, and it got worse until its on constantly. i almost positive its jsut the sensor, im in iraq right now and never messed with it, but im pretty sure all you have to do is find the sensor wire or watever in the ebrake handle part and adjust it so its not so sensitive, i think its just loose because i can mess around and make it flicker or go off. shouldnt be a big thing
Old Jan 1, 2006 | 02:17 AM
PsiQo1's Avatar
PsiQo1
ill lwt you kno..im gonna hafta rip **** apart i guess to ger to the bottom of this ... happy new years all..ahahahaha..alkihol.mmm
Old Jan 1, 2006 | 08:30 AM
SC3005SPD1's Avatar
SC3005SPD1
this happens to me but when im stopping. If i press on the brakes hard the brake light comes on. I have a 5spd also
Old Jan 1, 2006 | 09:39 AM
setwire's Avatar
setwire
Your problem is most likely low brake fluid.
