Supra coilovers
Old Dec 10, 2005 | 07:58 PM
ROPADOPA's Avatar
ROPADOPA
Default Supra coilovers
I apoligize ahead of time if this has been talked about here but i searched and had no luck.
I have put mk4 supra coilovers on a sc but have not tried them on a gs also mk4 brakes on an sc and i see that the front brakes go on the gs but do the coilovers swap out. ill be checking part #s out just thought some one could chime in and clue me in thanks-
Old Dec 11, 2005 | 08:19 AM
HKGS300's Avatar
HKGS300
Supra coilovers will not fit a 2ndGen GS. The rear Supra shock has a fork design, while the GS is using a bushing.
The 1stGenGS has a similar shock design to the Supra, but the rear GS shock is longer than the Supra.
Old Dec 12, 2005 | 06:25 PM
GS400kid's Avatar
GS400kid
How about the front, will it fit?
Thanks!
Old Dec 12, 2005 | 06:38 PM
ROPADOPA's Avatar
ROPADOPA
took the words right out of my mouth. I guess what im trying to find out, is what parts do fit and dont as i own a ls400 and a gs300 and get the opertunity to work with supra parts.
Old Dec 15, 2005 | 03:35 AM
HKGS300's Avatar
HKGS300
You probably can install the LS400 or Supra front shocks on a GS300, but the valving /demping force may not be suitable for the GS.
Also, height may be different, i.e. i expect the LS400 fronts to be longer than the GS so probably you may not be able to drop your GS enough.
For installing only LS400 or Supra fronts,the car may be unbalanced, and the ride may be even worse than stock.
Old Dec 29, 2005 | 07:47 AM
jmax.garage's Avatar
jmax.garage
what about the brakes of a TT MKIV supra on a MKI GS300? I'm talking front and rear assys.
Old Dec 29, 2005 | 08:55 AM
HKGS300's Avatar
HKGS300
brakes will fit, but you may need spacers.
Old Dec 30, 2005 | 10:44 AM
jmax.garage
what about brackets and how big of a spacer?
Sactolex
Feb 22, 2016 01:33 AM
horent135
GS - 1st Gen (1993-1997)
May 13, 2011 08:07 AM
1of120
Feb 5, 2010 06:35 PM
SC400DRFT
Oct 17, 2006 04:58 PM
erollinc
May 13, 2006 10:41 AM
