torque specs for daizen sway bars
Old Jun 4, 2005 | 09:28 AM
rominl's Avatar
rominl
exclusive matchup
why calling my name again
i know for a fact that on the sc430, you NEED to flip the end links to the other side, coz' if you dont', it will rub against a bolt on the suspension.
but i don't recall reading that on the GS. i can try to see on my gs4 and see if i can find out the answer
Old Jun 4, 2005 | 09:40 AM
JellyBean's Avatar
JellyBean
bt430's public profile says SC430. So it sounds like rominl's hunch is right. The installation on that thread must be on a SC430.
EDIT: And the thread is in the SC430 forum. Looks like a false alarm, corkycal. Looks like you're being very careful and methodical. You'll be fine.
Old Jun 4, 2005 | 09:58 AM
corkycal's Avatar
corkycal
ahhh, sigh of relief..........
yes jellybean, todd was referring to SC models. I'm glad I did it right and this brings this thread to a closure.
thanks jellybean and rominl.. you guys are the best!!!!
Old Jun 4, 2005 | 09:59 AM
corkycal's Avatar
corkycal
Henry, we call you because you're "see fu"
Old Jun 4, 2005 | 01:40 PM
lexforlife's Avatar
lexforlife
calvin
congrats on your new toy.. your install is perfect , thefronts are a direct swap over your rear mount is perfect , just make sure to tighten the rear sway link using the allen key inside the bolt while turning the nut with a 14mm wrench for if its not tight it will come loose quickly.. i see you have put it in the neutral position.. if you are a awake driver , you can put it in the position closest to the bar the aggressive setting and you will be for a real treat around corners , but be careful , the *** end will whip around on that setting..
now you need to finish off your susp with some toms pieces , the 6piece is a requirement and a lower control brace to tie everything together and then you can fool arounf with some of those M series out there
great job bro
Old Jun 4, 2005 | 04:50 PM
rominl's Avatar
rominl
exclusive matchup
man, i am indeed the "see fu" for a lot of people, haha.... damn
anyway, i checked my car, no need to flip the front, just like wht ed said. todd did the install on my car so you know it's right.
Old Jun 4, 2005 | 09:05 PM
BA_GS400's Avatar
BA_GS400
I hope it's not too late for this, but I'm compelled to mention something because of the mention of jack-stands in one of the earlier posts.
I'm about 98% positive that you should only tighten you're nuts and bolts to the torque settings when ALL 4 WHEELS are on the ground. True for most suspension related hardware, save for shocks.
Old Jun 4, 2005 | 09:29 PM
corkycal's Avatar
corkycal
ed,
thanks, i've waited long enough for these. the cornering is great! doesn't feel like a boat anymore.
Originally Posted by lexforlife
calvin
great job bro
Old Jun 4, 2005 | 09:48 PM
Neo's Avatar
Neo
The One
All my suspension braces (including the sways) were installed on a lift. It would be pretty hard to crawl under the car to torque the bolts with the wheels on the ground.
Old Jun 5, 2005 | 12:22 AM
rominl's Avatar
rominl
exclusive matchup
let's just say it's impossible for anyone to craw under my car (and a lot of other members' cars) when it's on the ground. with less than 5 inches of clearance? forget it
everything is torqued on the lift in my case too
98GSOwner
Suspension and Brakes
Mar 20, 2018 01:49 PM
Defratos
IS F (2008-2014)
Mar 19, 2016 10:29 AM
TXFM
Apr 30, 2015 12:00 PM
IS350atWOT
IS F (2008-2014)
Jul 29, 2012 08:06 PM
sc400
Jun 17, 2004 08:24 PM
