click click click!
Old 05-11-05, 06:22 PM
Chigga
Chigga's Avatar
Default click click click!
I jsut got back home from a vacation, I drove the car around and notice the click sound from the brakes are REALLY loud when going very slow.
IIRC that it's got to do with something on the back of the caliper and applying grease etc. Can some one tell the exact detail to fix this?
Old 05-12-05, 09:13 AM
TLW
TLW's Avatar
have you recently painted your rear calipers ?
there is a pin you''lll see when you take off the wheel
a little difficult to explain but pull that pin and put some Antisieze on it
sorry the pin is on the rear brakes holding in the rear brake pads
its held in place by a clip
Old 05-17-05, 05:55 PM
TLW
TLW's Avatar
just rethought this
check your suspension
im not sure what you have ....springs or coilovers
but make sure they are all the same height
it might be too much load on the rear shocks which is putting stress ont he rear bearings
which might be making the click as well
might have to adjust to lighten the load on the rear
let me know how it turns out
Old 05-19-05, 04:50 AM
TLW
TLW's Avatar
and duh the most obvious answer this is what is what i should have told you first ..my bad
...check the tires for nails and rocks
check around the brakes to see if soemthing lodged up in there
i keep thinking about this post ....if you have an extra set of tires
put them on and see if the noise goes away
Aspect
Suspension and Brakes
07-20-18 05:10 AM
peasodos
06-23-17 12:36 PM
aggiez28
03-28-16 09:40 PM
CAK 500
03-29-11 06:04 PM
brians00rx
RX - 1st Gen (1999-2003)
09-21-07 01:41 PM
Quick Reply: click click click!
