Just installed Daizen sways on my bone-stock GS430
Just installed Daizen sways on my bone-stock GS430 (running on 16s) and I love it. I set the rear bar to the softest setting (most understeer) and even then I can tell I need stickier rubber. I didn't notice any increase in NVH, but the car corners flat. It's now more fun to drive than our Odyssey "Type R" minivan. (If you've ever driven one, you know what I mean )
It took me approximately 5 hours to swap out the sways all by myself. It's definitely a very straightforward DYI project. It you're contemplating it, just make sure you spend a night searching the forums for all the hints (torque values, reversing the end links, loosening the lower shock bolts, etc.) Once you get under the car, it all falls into place.
I should note that the front bar's passenger side mounting holes were too close together. I spent about one hour (or longer) reaming out the holes with a drill to get a fit. The installation instructions that came with the bars were adequate, but not great. All the hints in the forums, however, were awesome. Thanks, y'all
Just saw your thread on the sways. Thanks for the input
Did you get the Daizen bushings also?
I'll safely assume that you have no suspension set-up yet when you say "bone-stock"
I have the bilstein shocks with stock springs and daizen bushings while still on the teeny 16s (no sways) and I can say that it's 7-8/10 better already for me
I want to jump on the TRD LCB-only $129!!!. I wonder how much that will also help with cornering?
exclusive matchup
Originally Posted by LEXUS_KID
How are they compared to TRD sways?
Daizen and trd sportivo still maintains that stock feel while improving cornering.
.....and yes jellybean, did you get a chance to compare them with TRD sways yourself?
https://www.clublexus.com/forums/sea...searchid=79387
Well, I read 3 pages of trd vs. daizen and the conclusion is trd blue is a lot stiffer.....a little cross-eyed now
.....and yes jellybean, did you get a chance to compare them with TRD sways yourself?]
BTW, my priorities were to increase cornering ability while keeping as much of the stock ride as possible. I felt--based strictly on all the reading in these pages--that the Sportivos were too conservative, and the TRD blues too radical. Hope this helps.
exclusive matchup
Originally Posted by ILOVEGIRLS
i remember seeing a thread on "how to" put LS430 calipers on the GS but i cant find the thread anymore. does anyone have the link? yes, i searched but all i found was info that it needs a bracket, i couldve sworn i saw a thread that it didnt...
and thanks for the comparison link GS3Tek, not sure if we need another comparison again
are you looking for ls430 on front or rear for i do have them mounted on the rear of my gs400 and the fronts will work as well with bracket
ntwrkguy1
03-06-16 09:23 PM
