supra brake conversion
Old Mar 29, 2005 | 03:03 PM
mart's Avatar
mart
Originally Posted by aliga
you need 2.75" clearanace from the rotor to the wheel spoke, if you have that, then your fine.
Is that for Supra or LS calipers? I know its mainly to do with spoke design, but whats the chances of LS ones fitting behind a 40 offset?
Old Mar 29, 2005 | 04:06 PM
aliga's Avatar
aliga
Former Sponsor
2.75" to the spoke for any wheel.
Old Mar 30, 2005 | 09:28 AM
mart's Avatar
mart
But for which calipers LS or Supra
Old Mar 30, 2005 | 10:04 AM
aliga's Avatar
aliga
Former Sponsor
i measured that for the LS caliper.
Old Mar 30, 2005 | 11:32 AM
p.hase's Avatar
p.hase
Default 16" wheels fit on LS400MK2 calipers
got my LS400MK2 calippers from aliga installed together with 315mm Brembo rotors yesterday. 16" OZ Opera rims fit on these calippers perfectly. i think they are 16x7.5" with 40mm offset.
exactly these wheels are sold across Europe as "winter wheel set for the old LS430". the clearance is about the same as in the LS430. about 2mm space in outside diameter and about 5mm towards rim.
the SC400 looks great with these rims. very very sporty and classy.
i cant tell much to the stopping power of the new calippers/rotors. my LS430 still brakes 200% better. but it is already a slight improvement noticable. dealer said NOT to brake hard for minimum of 300 miles. LS430 manual says 200 miles.
i found out the back rotors are warped and that one of the 4 pads is nearly gone.
Old Jun 30, 2006 | 10:09 AM
jpvarghese's Avatar
jpvarghese
Would '95+ LS400/430 wheels be enough to support the clearance required by the TT brakes? I assume the TT brakes and the LS 4-pot brakes are similar in dimension.
-Justin
Old Jul 2, 2006 | 04:57 AM
dejacky's Avatar
dejacky
Question
Is your LS430 stopping much better than ls400 calipers just because the LS430 brakes are that much better? Or, are other LS430 design factors contributing to the increased stopping power? Also, how can one fit LS430 calipers on the SC300 and SC400?
Old May 26, 2023 | 08:16 PM
MikesLexo's Avatar
MikesLexo
Anyone know does the 2007 is250 dual piston calipers works ? If so, do i need the is250 pads and rotors or can 2010 and up rx350 pads and rotors ? Thank
SorrGwa
Suspension and Brakes
64
Oct 14, 2013 05:14 PM
bugeyeGS
Mar 18, 2008 06:00 PM
TecnoSmurf
Nov 14, 2007 02:07 AM
Joe C
NELOC
23
Feb 20, 2007 05:19 PM
JWgs430
24
Jan 2, 2004 10:41 AM
