I need some answers please
Old May 26, 2023 | 03:18 PM
Cole23's Avatar
Cole23
3rd Gear
Default I need some answers please
So I took moved the throttle body over to replace ignition wires and spark plugs and I put everything back and started the car and it just revved to the max without me pressing anything. I believe it's the throttle cables from where I un loosened the nuts that held them together and wheres theres no resistanceon the gas pedal. If it is the cables, how tight/loose should they be or if it's something else then I would like to hear about it. The picture below is how I currently have em
Old May 26, 2023 | 09:10 PM
Tallyhoe's Avatar
Tallyhoe
Best bet is to remove the intake tube and see what the butteefly is doing. If it's open then you can manipulate the cables until it's closed, or sorta closed. Additionally check to see if the cabke is not caught on something, or you inadvertently installed the cable incorrectly
mtucci3
Mar 28, 2022 10:14 PM
BGG
Jan 8, 2016 02:17 PM
joeker
Jan 12, 2009 12:39 PM
want sc300
Nov 6, 2007 11:40 AM
TRE
Maintenance
17
Feb 29, 2004 08:05 PM
