supra brake conversion
Old Feb 2, 2005 | 06:29 AM
Goldark's Avatar
Goldark
Default supra brake conversion
what do I need for the brake conversion?
Supra calipers (are LS400s just as good?)
Rotors
Pads
SS brake lines?
does anyone on CL sell the complete kit or do I just call up my local Toyota dealer?
Old Feb 2, 2005 | 06:39 AM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
Goldark,
You can get these used often in our classifieds forums, or Steve Ganz / Carson Toyota holds a GB on them every couple of years. A similar alternative is the LS400 brake conversion kits that Aliga sells (also 4 piston but rotors are a tiny bit smaller).
For details on what you need... did you try to search? I know there are at least a dozen threads on this conversion. I'll look for a couple for you in a sec.
Also - you will need either Supra TT wheels or other high disk fittment brakes with the right kind of spoke design to clear these very big brake calipers.
OK for searching I used 'supra brake parts' and found these right away among others. Try it
https://www.clublexus.com/forums/sho...ra+brake+parts
Old Feb 2, 2005 | 08:11 AM
DIrEctQL's Avatar
DIrEctQL
Chicago Lexus Club Moderator
Originally Posted by DaveGS4
Goldark,
Rob,
If you want to know what parts you need just ask me.
Chris
Old Feb 2, 2005 | 07:35 PM
NoLongerA13bFan's Avatar
NoLongerA13bFan
Do you actually have to use SS line or can you reuse the sc rubber lines?
Old Feb 2, 2005 | 07:52 PM
One HoT's Avatar
One HoT
CL Folding 10,000
It's not mandatory to use SS lines...
Old Feb 2, 2005 | 09:03 PM
DIrEctQL's Avatar
DIrEctQL
They sure are if you are installing the rear.
Chris
Old Feb 3, 2005 | 03:36 AM
NoLongerA13bFan
When you order rotors do you just get the ones for an LS400?
Old Feb 3, 2005 | 04:39 AM
aliga's Avatar
aliga
Former Sponsor
if you are using ls calipers, order the 95-00 ls rotors.
Old Feb 3, 2005 | 11:42 AM
mikeloc24's Avatar
mikeloc24
I'll be getting a set from Gazi in a couple of months
Old Feb 3, 2005 | 01:26 PM
NoLongerA13bFan
I know this has been asked a bazillion times but does anyone know if a set of Enkei RPO!s 18x8 with a 35 offset will clear the calipers (they worked fine on the much smaller diameter 300zxTT brakes) .
Old Feb 3, 2005 | 02:06 PM
aliga's Avatar
aliga
Former Sponsor
you need 2.75" clearanace from the rotor to the wheel spoke, if you have that, then your fine.
Old Mar 25, 2005 | 07:35 AM
ChronoJ1's Avatar
ChronoJ1
a little off topic, didn't want to create a new thread.
I have a set of TT calipers that's been sitting in my garage for over a year, and it is extremely dusty and covered with brake fluid.
My question is, what do you clean it up with? Is it okay to clean it with water and dish washing soap?
Old Mar 25, 2005 | 08:38 AM
/Aerostar\'s Avatar
/Aerostar\
Brake parts cleaner
Old Mar 25, 2005 | 10:24 AM
ChronoJ1's Avatar
ChronoJ1
Originally Posted by /Aerostar\
Brake parts cleaner
Old Mar 29, 2005 | 08:46 AM
THE_CEO's Avatar
THE_CEO
LOL...funny
CEO
