Engine and transmission spacer.
Old Aug 22, 2024 | 08:41 AM
llilkvsh's Avatar
llilkvsh
3rd Gear
Default Engine and transmission spacer.
This sounds like a stupid question but I’ll still shoot. I’m looking at installing engine mount spacers (gs430) to get more oil pan clearance. I don’t want to mess with installing the transmission spacers but would not putting them in cause problems? Could the engine being up an extra 10mm cause any issues with the driveshaft or transmission itself? Or just play it safe and put the transmission spacers in aswell.
Old Aug 22, 2024 | 08:48 AM
Not sure I understand the question. Raising your engine will raise the transmission as well although less due to angle/distance and this will stress the transmission mounts.
Old Aug 22, 2024 | 09:39 AM
JonGS3's Avatar
JonGS3
Why? If your engine and trans mounts are original I'd replace those first since they're probably collapsed.
Old Nov 23, 2024 | 11:24 PM
dwoods801's Avatar
dwoods801
Are you planning wanting to lower your car an insane amount or something? The only reason I can think you want more room under the oil pan is if you’re planning on raising the whole suspension cradle or something? You could just raise the engine and not worry about the transmission, unless you’re looking for every MM and the engine is hitting the hood or something, then there is no reason to worry about the trans mount
dakrause
RX - 1st Gen (1999-2003)
Nov 15, 2024 12:32 PM
llilkvsh
Suspension and Brakes
Aug 22, 2024 08:36 AM
datstockls
Mar 2, 2021 02:06 PM
Cursedrx35
Mar 6, 2016 04:27 PM
cdvmagic
Maintenance
Dec 16, 2006 03:25 PM
