Help! ABS Trac Lights after struts and spring replacement
Need some help! A couple weeks ago I did a strut and spring replacement along with LCA bushings on my 2006 Lexus IS350. On the driver side front, I accidentally ripped the abs harness and the lights appeared on my dash, so I replaced it with a non OEM harness from ebay. I did the same with the passenger side front and there are still lights on the dash. Does the harness need to be an OEM harness or is there another thing I should be checking? It happened immediately after the strut and spring replacement. Thanks!
Last edited by wlelp; May 25, 2024 at 04:05 PM. Reason: Forgot to include the lexus model.
Brugada
GX - 2nd Gen (2010-2023)
Aug 17, 2021 10:05 AM
waLIEN
CT 200h Model (2011-2017)
Jan 8, 2021 04:59 PM
