Site Suggestions & Problems Bring up any suggestions, questions or problems concerning ClubLexus. If you need to test a forum feature, post here too. Note - questions about your Lexus do not belong in this forum!
Why are pictures not uploading
Old Dec 24, 2004 | 11:03 AM
chuckb's Avatar
chuckb
Default Why are pictures not uploading
How come some people are able to add photos and I still can't. I know other people are getting the same problem-It says "NOT VALID IMAGE" no matter what pic I try to put in?
Old Dec 24, 2004 | 06:03 PM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
Chuck,
We aren't going to help you much with this until a few days after the holiday. I'm pretty sure you can upload pics to the gallery and link them via IMG still. (see the FAQ sticky at the top of the photoshop forum if you don't know how to do that).
Thanks
D
Old Dec 28, 2004 | 03:15 PM
Lexkost's Avatar
Lexkost
I have the same problems and it is getting real old !!!!!
Old Dec 28, 2004 | 07:34 PM
DaveGS4's Avatar
DaveGS4
Dear Scrooge,
Our tech guys needed a couple of days off for Christmas to be with their families. Can they have them please without you beating them about the head and shoulders?
Seriously, we know this is an issue but it is a lower priority than the cookie login issue. There is a very simple workaround that allows you to post pictures in every post you want to. So use that instead if it gets 'too old' for you.
A) upload your picture(s) to the gallery
https://www.clublexus.com/gallery/uploadphoto.php
B) go the picture in the gallery. Highlight it, right click and choose the properties. Grab the picture URL and copy into your clipboard(see 'Method b' link below for more help if you need it) https://www.clublexus.com/forums/sho...362#post971362.
C) Start your post in the forum. Click on the little mountain button to insert an image . A popup box will appear and you paste your picture URL into it. This will automatically format the IMG tags for you and the picture will appear when you post your reply.
It sounds complex but its not. Very easy to do once you've done it once before. If you have problems making it work, just try it and then post here and someone will help you out finishing it if it isn't working .
Old Dec 28, 2004 | 07:50 PM
chuckb's Avatar
chuckb
I just tested Daves above method and it worked perfectly
Old Jan 12, 2005 | 01:22 PM
1NICESC430's Avatar
1NICESC430
Testing
Where's the bird?
Old Jan 23, 2005 | 05:42 PM
Matters's Avatar
Matters
Test run
Old Jan 23, 2005 | 05:45 PM
Matters's Avatar
Matters
Old Jan 25, 2005 | 11:13 PM
Matters's Avatar
Matters
attached photo test
varcity64
Jul 16, 2009 11:38 AM
19ES250
Dec 1, 2007 02:44 PM
casey225
May 28, 2006 06:58 PM
redgs4
13
Dec 6, 2003 10:23 PM
