Site Suggestions & Problems Bring up any suggestions, questions or problems concerning ClubLexus. If you need to test a forum feature, post here too. Note - questions about your Lexus do not belong in this forum!
No images in posts
Old Aug 25, 2025 | 01:36 AM
mrperfekt's Avatar
mrperfekt
10th Gear
Default No images in posts
Hi there!
I don't see any pictures in posts here, because my browser (Safari 18.6 on macOs 15.6.1) blocks them because of CORP policy violation. The same thing in the latest Chrome.
I don't use any ad blockers.
I couldn't even upload browser's console screenshot here, it stops at 90% uploading with the same CORP error.
Old Sep 5, 2025 | 01:52 AM
mrperfekt's Avatar
mrperfekt
10th Gear
Anyone? This problem is very annoying, I don't see anything here
Old Sep 5, 2025 | 09:15 AM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
mrp, I was hoping @IB JT would chime in as he's probably best positioned to help you. I'd start off by saying this sounds like an issue being generated by your device, not the forum software just by the message you are getting and you are the only one chiming in having this problem.
Can you confirm that this is a work device or if a personal device, does it have a security policy loaded on it from your place of employment? Have you tried accessing the forum from another (non-work) device and do you have that same issue there?
Old Sep 5, 2025 | 10:38 AM
mrperfekt's Avatar
mrperfekt
10th Gear
No, this is my personal laptop. I also have the same problem on my iPhone, no matter which network I use
Old Sep 5, 2025 | 02:16 PM
DaveGS4's Avatar
DaveGS4
And no work security software or policy loaded on both devices to allow you to access work email and applications from them?
Your IP location shows Poland, are you located there? Using a VPN?
Old Sep 5, 2025 | 02:47 PM
mrperfekt's Avatar
mrperfekt
10th Gear
Yes, I'm in Poland.
We don't use any security software for work or ant VPN, I have a direct Internet connection via local ISP (Orange). I guess the problem is related to my region, but I'm not sure, because cross-origin resource policy is a matter of server configuration (CDN in this case) and does not rely on the client location.
I also have a Windows PC machine with Chrome here, so I'll check how it works and post update including links to console screenshots.
Old Sep 8, 2025 | 11:27 AM
mrperfekt's Avatar
mrperfekt
10th Gear
So I get these errors (Google Chrome console on a PC):
It is not related to my specific hardware, this is a server-side issue.
Maybe that's Cloudflare misconfiguration - because when I try to open the image directly I see Cloudflare DDoS protection page first, then the image opens. So maybe some regions in the configuration marked as unsafe and CORS/CORP policy fails here.
I'll try to use VPN to check this and update this post.
UPD: Yes, when I use VPN with US server, I can see all the images here. So the problem is in Cloudflare.
Last edited by mrperfekt; Sep 8, 2025 at 11:42 AM. Reason: checked VPN with US server
