Low beam quit working while driving
I started going from a stop light; low beams shut off, battery symbol on dash lit up. The fogs and high beams work.
It'll be awhile before I can get under the hood. Any ideas what could cause this? My first guess would be check the fuse.
I should have stated, I replaced my starter, alternator, battery about 2 years ago. My battery (autozone duralast) was 3 years old prior to me replacing it two years ago under a partial warranty. So maybe it's a POS and I'll switch brands.
My high beams still work which is the weird part.
Also, the battery light is off.
Had a spare headlight element. What are the chances both low beam elements went out the same time? Because that's what happened.
