Help with fitment and new wheels.
Hi everyone,
I have a 2015 AWD Lexus IS350 F Sport. I need some help with finding reliable spacers for my new wheels. I bought Aodhan AH08s in a staggered setup. The fronts are 18x8.5(+35mm offset) and the 18x9.5(+30mm) in the rear. I took them into Les Schwab to see if everything will fit the way they are. Unfortunately the front wheels will not fit because of the size of the brake calipers.
So my friends recommend getting spacers, specifically 15mm. I am trying to go for a nearly flush/flush look. What I need help with is to where I could buy reliable spacers and what to look for exactly. Thank you so much for your help!
Dralsi (03-25-19)
having 18x9.5+30 in the rear will clear fenders with stock control arms if the tires are thin enough. if you throw on a 245/35, you should be good
i have 18x10+38 with 255/35 on there and they clear with stock control arms. the outer lip on your wheels should only be 2mm further out than mine, immaterial
I still have it on stock suspension but I am thinking of getting coilovers. I don't plan on going that far out, probably somewhere between the 15-20 range.
Muti007
08-14-14 06:50 PM
