MultiMedia System keeps restarting
Old Mar 19, 2019 | 06:52 PM
kv1193's Avatar
kv1193
Question MultiMedia System keeps restarting
Hello,
From last couple of days my multimedia system keeps restarting. It sometimes restarts 5-6 times then stays for sometime and then restarts it. I read the forums where it was mentioned to remove the 15A fuse and then restart the car to see if that helped. It didn't. I removed the negative terminal of the battery. Waited 5-10 minutes put it back.Restarted car it was fine for a day then it started restarting again. Anyone noticed same kind of issues on their car? Anything which I can do for troubleshooting?
Thanks
Old Mar 19, 2019 | 07:20 PM
Sasnuke's Avatar
Sasnuke
Is your vehicle a 2014 without ML audio?
Old Mar 22, 2019 | 01:02 PM
MadmanJay's Avatar
MadmanJay
I have a 2017 IS 300 and have this problem. Seems to only occur in the winter with colder weather for me. I made several recordings of it happening and showed my dealer the video. They have ordered me a replacement which has just come in and I will be getting it installed next week.
Hope it resolves my issue.
Old Mar 22, 2019 | 11:46 PM
Panzer126's Avatar
Panzer126
My 2014 is350 fsport with ML did that, started with just occasional then eventually was constantly restarting. SInce my car was out of warranty I had to replace it myself. Went to a lexus master tech and the radio part alone was $2150 and had to be ordered through the dealership network.
Old Mar 23, 2019 | 07:41 AM
KYLexusMkr's Avatar
KYLexusMkr
I had this issue happen to me before, out of the blue it would just shut off and reboot as though the car had been restarted. I checked online and the forums to no avail. After a good week, of trouble shooting, I found that it only happed when I was leaving my iPhone, 6s at the time, connected via the usb to charge. It was the only other thing I could find out of the ordinary. I got a 12v charger started using it and had no issues since. Now I don’t know if maybe this could pertain to you, but I wanted to throw it out there. It did all happen when I first bought my 17 IS, it’s not a ML system, just the Nav system.
Old Mar 23, 2019 | 11:48 AM
MadmanJay's Avatar
MadmanJay
You may be into something about the iPhone. When I first got my car I rarely plugged in the phone to the USB port because my iPhone 7 was new and the battery lasted all day. However for the last year I have been plugging it in and that is when I noticed it reboots. However for me it only seems to happen in the colder months. (December - March) so I wonder if it is some sort of cold solder joint or Something.
Either way, they are replacing mine next week with a new one so we will see if it fixes the issue or not. Problem is I may have to wait until next winter to really know. Lol
Old Mar 23, 2019 | 12:50 PM
KYLexusMkr's Avatar
KYLexusMkr
Please do let us know for sure. I know mine stopped when I stopped charging it there. Since it stopped, I never tempted fate again, figuring the dealer would blame me for the units failure if I kept doing it.
Old Mar 24, 2019 | 07:08 AM
kv1193's Avatar
kv1193
No it is the standard lexus audio system not the ML one.
Old Mar 24, 2019 | 07:09 AM
kv1193's Avatar
kv1193
I unplugged whatever was plugged into the USB ports. Its stable sometimes like for a day then next day its brutal. Just stuck in a loop
Old Mar 24, 2019 | 07:10 AM
kv1193's Avatar
kv1193
holy that is expensive. Did you look anything for aftermarket ones?
Old Mar 25, 2019 | 06:08 AM
Panzer126's Avatar
Panzer126
From what I found anything almost plug and play would required the OEM system to be functioning. Car wouldn't even read a USB as it keeps powering off and on.
Old Mar 25, 2019 | 03:54 PM
E46CT's Avatar
E46CT
My friend's 2G IS350 is having a similar problem. He can't turn on his fan/AC cause it's integrated with the main unit display.
bc6152
ES - 7th Gen (2019-2025)
68
Sep 8, 2019 08:53 PM
PooPaws
Jul 6, 2018 11:55 AM
talbin
Feb 12, 2007 07:15 PM
Lexy GS430
Aug 31, 2006 06:36 AM
