are ebay ps pumps any good?
Old 09-20-18, 09:16 PM
dakota166
dakota166's Avatar
Default are ebay ps pumps any good?
Are the 60 dollar power steering pumps safe to use? the ones on autozone are pretty expensive.
Old 09-21-18, 01:24 AM
Moarpower
Moarpower's Avatar
buy 1 and see. They wont be great but honestly, it will probably work for a few years
Old 09-21-18, 05:47 AM
python
python's Avatar
go to rock auto..get a cardone
Old 09-21-18, 08:55 AM
bradland
bradland's Avatar
Stay away from Autozones DURALAST brand. Not just PS pumps but basically anything with the name Duralast on it.
spuds (09-21-18)
Old 09-21-18, 09:03 AM
YODAONE
YODAONE's Avatar
No. Not unless new OEM overstock.
Buy a new pump from the dealer.
Old 09-21-18, 10:19 AM
Michael88
Michael88's Avatar
The PS Pump is in such a bad location, that you are better off getting a quality OEM pump, if you can afford it. If you can't, then you would have no choice but to take the gamble. Importantly, LS400 pump don't take PS fluid. They take ATF. That can make a huge difference. Please correct me if I am wrong.
Old 09-23-18, 07:50 PM
Fit1too
Fit1too's Avatar
The R&R is a big consideration, but sometimes price is the biggest.
I've heard negative things about using starters, alternators, etc from Autopart stores, especially if they are difficult to R&R.
I checked the rockauto site and their cheapest pump is $72 with a $50 core charge for a up front total of $122, but it is manufactured by Lares and I've never heard of that company.
The owner's manual lists Dextron II or III Automatic Transmission Fluid (ATF) for the power steering system.
It is soooo important to use the correct fluid in a vehicle's different systems, which can be found in the owner's manual or thankfully for us at the drivers.lexus.com/lexusdrivers site.
Old 09-24-18, 01:50 PM
dveneman
dveneman's Avatar
You might consider researching "How to" posts on this forum.
Cleaning the internal strainer and replacing the o-rings may be all that is needed.
But you may discover that a leaking hose also needs replacement.
https://www.clublexus.com/forums/ls-...0-ls400-s.html
astowell
01-11-21 02:29 PM
groomerz
03-17-17 12:09 PM
rick1987
09-06-15 07:05 PM
Greg5OH
01-05-15 09:08 AM
warminwisc
08-08-14 05:39 AM
Quick Reply: are ebay ps pumps any good?
